Post deleted by Defbob #723093
06/13/10 03:12 PM
06/13/10 03:12 PM
Anonymous OP
Anonymous OP
Re: AN sizes for radiator cooling #723094
06/13/10 03:30 PM
06/13/10 03:30 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it really depends on how much pressure the pump can build. i've been using the shogun type (actually a teel bilge pump) which has a -10 suction and -8 discharge. with an aluminum radiator and flexalite black magic fan i haven't had any cooiling problems but it also depends on the HP you're making, which you will have more than me.
Re: AN sizes for radiator cooling [Re: jamesc] #723095
06/13/10 03:37 PM
06/13/10 03:37 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
#16 on most of our door car applications.
Post deleted by Defbob [Re: B G Racing] #723096
06/13/10 03:49 PM
06/13/10 03:49 PM
Anonymous OP
Anonymous OP
Re: AN sizes for radiator cooling #723097
06/13/10 05:12 PM
06/13/10 05:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I thought I saw 16 on top and bottom somwhere now I know on Donny's maybe ? or I am confusing myself with his breathers
Yes Fred,Don's has #16 top and bottom with the reverse cooling there are two #16s teed into one#16 to the top of the rad and one #16 from the bottom of the rad to the pump.The #12s are on the breathers. the car very seldom see 200 degrees and after a run it cools to 170 by the time he gets back to the pits.
Re: AN sizes for radiator cooling [Re: B G Racing] #723098
06/13/10 05:20 PM
06/13/10 05:20 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I am pretty sure that they arean16's on mine, with a Shogun manifold and pump.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: AN sizes for radiator cooling [Re: Dartsport540] #723099
06/13/10 05:28 PM
06/13/10 05:28 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Looks like #12 to me.
Re: AN sizes for radiator cooling #723100
06/14/10 01:36 AM
06/14/10 01:36 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
Here in Az. where the temps are high -16 drag cars, -20 for street cars. And the drag cars are built to hot lap with no problems
Re: AN sizes for radiator cooling [Re: Comp Chassis 2] #723101
06/14/10 07:12 AM
06/14/10 07:12 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
-12an on all my cars
