69 Bee front seat redo #723056
06/13/10 02:24 PM
06/13/10 02:24 PM
Texas
6packattk Offline OP
Texas
I am in process of removing seat backs for front seat so I can repaint and reupholster,my service manual does not cover how to take them off.I have to to put cover on the seat backs.Any help would be appreciated aside from ordering upholstery book.
Re: 69 Bee front seat redo [Re: 6packattk] #723057
06/13/10 02:42 PM
06/13/10 02:42 PM
Washington
69440 Offline
69440  Offline
Washington
If you have bucket seats, there will be a pair of screws on the bottom of the seat back, where it bends under. Remove those screws and pull down on the upholstered panel. Once it's off, you'll see 4 hooks that secure it in place. These hooks must hook properly when re-installing the back panel. This is a fairly simple process and you shouldn't have any trouble. Best of luck, Bill
Re: 69 Bee front seat redo [Re: 69440] #723058
06/13/10 02:51 PM
06/13/10 02:51 PM
Texas
Texas
It is a split bench,auto,it is probly easier than it looks,been trying to figure it out but am at a loss
Re: 69 Bee front seat redo [Re: 69440] #723059
06/13/10 03:13 PM
06/13/10 03:13 PM
Texas
Texas
Maybe this should say at top now,blind squirrels even find nuts once in a while,(as cab has said at times)it was quite simple once I quit worrying about messing it up and just started tinkering,now I should say who wants to know how to remove seatbacks on split bench seat on superbee or road runner for 69.It was so simple I feel humbled by it.Everything looks welded and pinned but there was a washer that holds it on like on the cheap axles on some wagons and carts.Now where do I get new washer for it?ha ha
Re: 69 Bee front seat redo [Re: 69440] #723060
08/30/10 08:04 AM
08/30/10 08:04 AM
South Florida
goalsetterpk Offline
South Florida
My 69RR Buckets were so bad the backs were long gone, any chance of pictures of these 'hooks' or the install process? I assume we can make the hooks or does anyone sell them, please? THANKS for your post.
cell phone 561 315 5576
Re: 69 Bee front seat redo [Re: 6packattk] #723061
08/30/10 08:29 AM
08/30/10 08:29 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
The serrated washers that grip on the end shafts to retain the seat backs are available at good hardware stores. ACE has them, probably Lowes and Home Depot too. Just measure the shaft diameter so you get the right size.
Re: 69 Bee front seat redo [Re: Dave Watt] #723062
08/30/10 11:57 PM
08/30/10 11:57 PM
South Florida
South Florida
THANKS for your kind reply, yep thats my problem I don't have either the serrated washers nor the end shafts they were long gone. Plymouth Service Manual is zilch help.
I have a call into a vendor here "Steves Parts" since it's OEM, if he gets me some I'll post pics here. Thanks Again.
Re: 69 Bee front seat redo [Re: goalsetterpk] #723063
08/31/10 10:19 AM
08/31/10 10:19 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
So the seat back pivot shafts are missing? They are welded on to the frame.
Re: 69 Bee front seat redo [Re: goalsetterpk] #723064
08/31/10 10:50 AM
08/31/10 10:50 AM
Washington
69440 Offline
69440  Offline
Washington
I normally make my own hoohs and pop rivot em to the new panel, that I also make. You need to have the bent metal strip for the bottom of the panel, that secures the panel to the bottom of the seat back with two screws. I'll dig up a hook or two, take a few pics and post. Bill
Re: 69 Bee front seat redo [Re: 69440] #723065
08/31/10 04:19 PM
08/31/10 04:19 PM
South Florida
South Florida
Steves Parts is sending me a set for both buckets and I hope to use the instructions here to get the seat backs attached. Will post pics.
I did a search but couldn't find anything, probably so simple I should have been able to figure it out (but still couldn't).
THANKS MOPARTS.COM FOR BAILING ME OUT AGAIN.
Re: 69 Bee front seat redo [Re: goalsetterpk] #723066
09/01/10 07:45 AM
09/01/10 07:45 AM
Washington
69440 Offline
69440  Offline
Washington
Well, as it turns out, I don't have any to photograph. All I have is the one I use as a pattern, and it, of course, is now flat. If you need any assistance though, send me a PM, with your number, and I'll call you. I'm always happy to help. Best of luck, Bill
Re: 69 Bee front seat redo [Re: 69440] #723067
10/08/10 10:43 PM
10/08/10 10:43 PM
South Florida
South Florida
