Replacing Cylinder Heads #722645
06/12/10 09:23 PM
06/12/10 09:23 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
What's up all. I've heard that it was a bad idea to install new/rebuilt heads on a high-mileage motor. Is that true,and if so, why? Is there anything I should watch out for? Thanks for any replies.
Re: Replacing Cylinder Heads [Re: 440child] #722646
06/12/10 10:29 PM
06/12/10 10:29 PM
I say it has more to with large amounts of cylinder psi increase.
this will accelerate the oil being pushed past the rings=smoke.
do a leak down test if it worries you.
anything beyond 10-12% is bad.
5% is a good average.
I say if the leak comes out good & the vales are sunk or not sealing, go for it.
Re: Replacing Cylinder Heads #722647
06/12/10 10:57 PM
06/12/10 10:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the motor is in good shape changing the heads will not hurt a thing unless you are going from open chambered to closed heads. Then the higher comprerssion my cause a little oil gettiing by the rings. I wouldn't worry about it.
