newer paint then organisol #722611
06/12/10 07:55 PM
06/12/10 07:55 PM
car48nut Offline OP
car48nut  Offline OP
With all the new models from chry,ford and etc, coming out, Is there a newer paint to use that is like organisol? I need to know if the organisol from Year One is compatible with base coat clear coat. If one of the new flat blacks will work, would not that be better to use? Any ideas? Thanks
Re: newer paint then organisol [Re: car48nut] #722612
06/12/10 08:29 PM
06/12/10 08:29 PM
Jacksonville Florida
elitecustombody Offline
As long as your base/clear is catalized and cured,there should be no worries,give the paint to dry for atleast a few days, avoid heavy coats and you'll be fine
Re: newer paint then organisol [Re: car48nut] #722613
06/13/10 03:10 PM
06/13/10 03:10 PM
car48nut Offline OP
car48nut  Offline OP
Re: newer paint then organisol [Re: car48nut] #722614
06/13/10 03:37 PM
06/13/10 03:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: newer paint then organisol [Re: Neil] #722615
06/14/10 02:27 PM
06/14/10 02:27 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Is this thread in Moparts archives? If not could it be put in? Thanks. If its already in there I could't find it.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
