torque #,s for 426 hemi
#722608
06/12/10 07:54 PM
06/12/10 07:54 PM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
any one have a torque pattern and how many pounds for a 426 hemi with alum heads also are ALL bolts torqued the same pounds?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: torque #,s for 426 hemi
[Re: toplescuda]
#722609
06/13/10 03:44 AM
06/13/10 03:44 AM
RapidRobert
My 67 "glenns" shop manual shows 70-75 lbs w no mention of any of em being less (or more) in this pattern which I am assuming is for OE iron heads. Not sure if alum is different but I believe that the clamping force needed is dependent on the gasket/fastener type/psi to be sealed rather than head material type but find out from someone else who knows for sure on this
