Re: Etching primer question...
[Re: 300by500]
#722344
06/12/10 01:34 PM
06/12/10 01:34 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I would use an etch primer on the bare spots, no point in spraying over the paint. Although myself I could probally use a high build primer to make sure all the scratched and stuff were filled and wetsand it before paint.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 69DodgeCharger]
#722350
06/12/10 07:22 PM
06/12/10 07:22 PM
Challenger 1
Cincinnati, Ohio
Only use etch primer on bare metal, keep it off filler and old paint.
Have to disagree with you there. I've been doing it for years and never had an issue. Besides there is always going to be some incidental contact between bodywork/filler and bare metal when using etch primer so what does a guy do in that instance? Tape off the filler spots?
minimize it all I was saying. This is the stuff I use. Read the tech sheet. web page
[Re: 300by500]
#722351
06/12/10 07:29 PM
06/12/10 07:29 PM
Challenger 1
Cincinnati, Ohio
I'm looking at PPG DPLF epoxy, and it says on their site that it should NOT be used over an etching primer, but that a metal conditioner should be used first.
PPG DP40LF Product Sheet
Looks like this may be the best way to go, for what I'm doing.
PPG etch primer DX1971 is ok to recoat with DP primers.
[Re: 300by500]
#722352
06/12/10 08:24 PM
06/12/10 08:24 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
For small projects and sand throughs I use Sherwin Willams GBP 988, it comes in aerosol cans and works great, http://www.sherwin-automotive.com/products/show_product.cfm?product=988If you're prepping engine bay, I'd avoid hosing on unnecessary materials,by doing so,you will cut down on chances of chipping and scratches, you can use GBP 988 over any surface/substrate without any problems, it has amazing adhesion properties and has never failed me, I use it quite often.It goes on nice and smooth with no builup,dries within a minute or two, I simply love this stuff Simply shoot one or two medium coats of GBP 988 followed by one coat of tinted sealer and then topcoated with your choice of color and clear.
