NEON ~SHUTS OFF WHILE DRIVING #721842
06/11/10 08:47 PM
06/11/10 08:47 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
96 2.0 automatic.
Starts and runs fine, after running about 10-15 minutes,it jerks like it's misfiring,then shuts off. Restarts after just a few minutes like nothing's happened.
Anything common with these? Cleaned battery terminals, as this did this a week or so ago. FWIW, battery light comes on, maybe this is common?
Fuel pumps fairly new, you can hear it pumping when you try to start it.
Clues anyone?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Magnumguy] #721843
06/11/10 09:39 PM
06/11/10 09:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
got codes?
The key on/off/on/off/on trick works.
Don't be the exception.
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Supercuda] #721844
06/11/10 10:08 PM
06/11/10 10:08 PM
S.E.Ohio
S.E.Ohio
got codes?
Tried that, and nothing. Just before it died, the check engine light came on.
Will a bad coil pack do this?
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Magnumguy] #721845
06/11/10 11:28 PM
06/11/10 11:28 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Replace the crank sensor and check the wiring from the sensor back through the harness. The wires like to melt together. Repaired a bunch that way. They where doing the same thing. No codes nothing.
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Todd] #721846
06/12/10 02:45 PM
06/12/10 02:45 PM
S.E.Ohio
S.E.Ohio
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Magnumguy] #721847
06/13/10 01:48 AM
06/13/10 01:48 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Mine did that when the fuel pump was getting weak- not dead- just weak- it still had 25 lbs but would misfire and stall such as what you are having. It may not hurt to put a guage on it and see what it's doing....
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: 72demon416] #721848
06/13/10 07:19 AM
06/13/10 07:19 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
My Neon SRT-4 ran the same way when I first bought it. I bought a fuel pressure gauge with a long hose from amazon.com. I put the gauge up on the windshield and went for a ride. In second gear the fuel pressure dropped to 24 lbs. I would Check your fuel pressure first.
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Magnumguy] #721849
06/13/10 07:31 PM
06/13/10 07:31 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My wifes 00 2.0 Neon eats plugs about once a year. It will do what you say and new sparkers clears it up. It's weird, but thats what it does.
Sheldon
Re: NEON ~SHUTS OFF WHILE DRIVING [Re: Magnumguy] #721850
06/13/10 08:55 PM
06/13/10 08:55 PM
central illinois
65dodgebob Offline
65dodgebob  Offline
central illinois
this is gonna sound crazy, but worth checking ou t. we had a similar problem and it turned out to be a loose ground connetion in the trunk area. pull down carpting under driverside trunk hinge to check it out. this was a factory grounding point for several things. some meathead had decided to ground speakers there and left the connection loose. car kept dying for no reason til i found this.
