68 GTX rocker moldings? #721034
06/11/10 06:55 AM
06/11/10 06:55 AM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
Trying to install repop rocker moldings, bought the repop clip kit too. How the heck do the black metal clips with the little wire spring thingy work? Thanks!
Re: 68 GTX rocker moldings? [Re: Silverbullet2] #721035
06/11/10 01:24 PM
06/11/10 01:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Typically the clips slide into/onto the molding, and the wire spring serves to hold them on the molding, then the molding is installed. The alternate method is to install the clips on the car and then work the molding onto the clips, but that's a pain in the butt.
Re: 68 GTX rocker moldings? [Re: topside] #721036
06/11/10 03:39 PM
06/11/10 03:39 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My 68 sport satellite had plastic clips installed in the body the molding would snap over. They would have a center that was plastic also that after the clip was slid into the body hole, you would push the center in so it would expand in the hold to stay in place.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 68 GTX rocker moldings? [Re: Silver70] #721037
06/11/10 04:55 PM
06/11/10 04:55 PM
SE Pa.
LimeliteAero Offline
SE Pa.
thats how 68's should be. Im not sure what year clips the OP is speaking of.
your problem could be attempting to use incorrect hardware.
Re: 68 GTX rocker moldings? [Re: LimeliteAero] #721038
06/11/10 07:04 PM
06/11/10 07:04 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
There are only plastic clips in rocker and lower fender. Molding snaps on. No spring clips on 68. Don't think any on 69 or 70 either.
