72 340 valve covers #721017
06/11/10 02:08 AM
06/11/10 02:08 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
what do the 72 340s look like i thought by 72 the pass side sheild was gone other than that they look exactly like 70/71's
Re: 72 340 valve covers [Re: ademon] #721018
06/11/10 07:45 AM
06/11/10 07:45 AM
around
1A1A1A1A1 Offline
1A1A1A1A1  Offline
around
On the drivers side valve cover, the high stand off wire loom, has a hole in it, unlike the 71's that do not have this hole. I think the intent was a plastic piece inserted into this hole, held the idle stop solenoid wire.
The 72 and VERY early 73 340 valve covers are fairly unique, but can also be found on the 72 318 engine with electronic ignition.
On a side note, by 1973 the 318 and 340 valve covers are the same.
Check out this link, it helped me, but it is not entirely correct, there are some minor errors.
http://books.google.com/books?id=phKNxZn...p;q&f=false
Re: 72 340 valve covers [Re: 1A1A1A1A1] #721019
06/11/10 09:53 AM
06/11/10 09:53 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Does the pass side have the sheild in 72? also the one i'm looking at has a different looking driver side standoff, its still tall but is bent.
Re: 72 340 valve covers [Re: ademon] #721020
06/11/10 12:28 PM
06/11/10 12:28 PM
around
1A1A1A1A1 Offline
1A1A1A1A1  Offline
around
No, there is no shield. The 71 & 72 passenger side 318 AND 340 valve cover is the same.
If the high stand off wire loom on the drivers side is bent at the top, then the valve cover is correct for 318 / 340 / 360 drivers side valve cover for 73 and 74, definitely not 72.
Re: 72 340 valve covers [Re: 1A1A1A1A1] #721021
06/11/10 12:51 PM
06/11/10 12:51 PM
around
1A1A1A1A1 Offline
1A1A1A1A1  Offline
around
Here is a pair of 100% correct 72's.
Re: 72 340 valve covers [Re: 1A1A1A1A1] #721022
06/11/10 12:59 PM
06/11/10 12:59 PM
around
1A1A1A1A1 Offline
1A1A1A1A1  Offline
around
If you are interested in seeing what 1973 318/340 valve covers look like, go to this ebay link.
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWNX%3AIT
Re: 72 340 valve covers [Re: 1A1A1A1A1] #721023
06/11/10 01:04 PM
06/11/10 01:04 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
well i know the 71's have the sheild, was mostly wondering about the 72 having them.
Re: 72 340 valve covers [Re: ademon] #721024
06/11/10 02:43 PM
06/11/10 02:43 PM
around
1A1A1A1A1 Offline
1A1A1A1A1  Offline
around
Sorry about that... you are correct, the heat shield is only on the 70 & 71 340's.
Someone should post or do an article on all the different 340 valve covers by year! Any mopar magazine editors reading this???
Re: 72 340 valve covers [Re: 1A1A1A1A1] #721025
06/11/10 02:47 PM
06/11/10 02:47 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Some orange painted 70 and 71's lacked the shield, most original (post April 71) blue painted 71's I've seen don't have it.
Re: 72 340 valve covers [Re: ScottSmith_Harms] #721026
06/14/10 09:31 AM
06/14/10 09:31 AM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
Did the rubber coated shield & wire clips come painted or were they masked off???
1971 BS23H1B
Re: 72 340 valve covers [Re: tx9cuda] #721027
06/14/10 12:11 PM
06/14/10 12:11 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
all i have seen were painted over,
Re: 72 340 valve covers [Re: ademon] #721028
06/14/10 02:56 PM
06/14/10 02:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, all painted over.
Re: 72 340 valve covers [Re: ScottSmith_Harms] #721029
06/14/10 04:21 PM
06/14/10 04:21 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
Thanks guys I'm getting ready to refinish mine now.
Bryan
1971 BS23H1B
