street to strip 66 dodge coronet #720967
06/10/10 11:06 PM
06/10/10 11:06 PM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
i have a 66 coronet. full steel heavy [Email]a@@[/Email] car. what gearing should i run 4:10 or 4:30?
the car wont be driven too far on the street 40 or so miles round trip.
spec's
383 flat top pistons unknown compression maybe 9.5 or 10:1
solid cam http://www.summitracing.com/parts/CCA-21-232-4/
ported 906 heads
eddy tm6 intake with a 850 holley dp
4 speed car
thanks!!!
ohh yeah 1/4 mile
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720968
06/11/10 01:38 AM
06/11/10 01:38 AM
San Diego
formula S Offline
formula S  Offline
San Diego
What size tire?
Re: street to strip 66 dodge coronet [Re: formula S] #720969
06/11/10 07:46 AM
06/11/10 07:46 AM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
sorry 29in
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720970
06/11/10 08:23 AM
06/11/10 08:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my old 67 w/ a 440 weighed 3850 w/ me (180) and a 1/2 tank of gas as raced. I'd think your 383 will like the 4.30's better. They really start making power over 3k. If it was a 440 I'd say 4.10's. Drive it like a rental!
Coming soon!!!!
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720971
06/11/10 09:33 AM
06/11/10 09:33 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I would start out with 4.30's and run it, then see what your mph is you might need more gear than that like 4.56 or 4.88's. Try these calculators http://www.wallaceracing.com/Calculators.htm they might help you with your decision.
Re: street to strip 66 dodge coronet [Re: formula S] #720972
06/11/10 02:44 PM
06/11/10 02:44 PM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
I run 430's with a 29 inch slick.
383man [Re: mike67net] #720973
06/12/10 12:05 AM
06/12/10 12:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use 4.30's in my 63 with 30" tires. Its a 440 with the MP .557 solid cam. Ron
Re: street to strip 66 dodge coronet [Re: formula S] #720974
06/12/10 06:51 PM
06/12/10 06:51 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
100% 0n the 4.30's.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: street to strip 66 dodge coronet [Re: HYPER8oSoNic] #720975
06/14/10 04:04 AM
06/14/10 04:04 AM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
thanks guys i ordered a set of 4:30's thanks!!!!
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720976
06/14/10 02:55 PM
06/14/10 02:55 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
If you are not driving it a ton on the street... 4.56. Those 383s will spin pretty good.
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720977
06/20/10 11:17 PM
06/20/10 11:17 PM
Desert Tracker
Desert Tracker
spec's
ported 906 heads
4 speed car
thanks!!!
ohh yeah 1/4 mile
Good Choice The cam and 4speed
WILL LIKE the 4.30's on the track. 13's should be no problem, mid twelves, maybe, with a little bit
of suspension tricks and FINE tuning !!!
Re: street to strip 66 dodge coronet [Re: 66coronet] #720978
06/21/10 01:50 AM
06/21/10 01:50 AM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
nice coronet do you have any more pic's? what size tir are you running on the rear?
i got the 4:30 in and i like it so far
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720979
06/21/10 09:55 AM
06/21/10 09:55 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
4.10 with 30" tire here
Re: street to strip 66 dodge coronet [Re: VernMotor] #720980
06/21/10 11:22 PM
06/21/10 11:22 PM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
30 in tire what rpm are you at when you pass the 1/4 line?? how wide are the 30's what brand?
nice coronet i like the scoop
thanks
i may be seting up a dana too i have all the parts to build one just gotta cut down the housing and order axles every thing else was free it will be a 4:56
so then ill will have a whole bunch a gearing to try
at the track
8 3/4 4:10 and 4:30
dana 60 4:56
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720981
06/22/10 09:05 AM
06/22/10 09:05 AM
Pittsburgh, PA
SmokeyBurnout 67 Offline
Pittsburgh, PA
Our 67 Dodge Coronet is a street/strip car as well.
It's a 440 30 over and runs 10.90's at 124mph
We run a 29x9 tire, I had Hoosiers at one point that were 30x9's but they still measured 29x9 with 4.56 gears. 1/4 traps at 6700, I shift at 6400. 55mph is usually the max cruising speed we prefer. We don't cruise it very far 10-20 miles or so. 4.30's would be fine but if you think about changing to the 56's they will be fine.
Enjoy and put some pics up!
Kara
Re: street to strip 66 dodge coronet [Re: SmokeyBurnout 67] #720982
06/22/10 11:02 AM
06/22/10 11:02 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Your clutch would like 4.56's better
Gus
64 Plymouth Savoy
Dana 60
Re: street to strip 66 dodge coronet [Re: fourgearsavoy] #720983
06/22/10 02:14 PM
06/22/10 02:14 PM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
thanks for all the info guys
Re: street to strip 66 dodge coronet [Re: dirtycj5] #720984
06/22/10 05:24 PM
06/22/10 05:24 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
shift 6000 go though at 6200-6300
