what do you suggest #720867
06/10/10 08:47 PM
06/10/10 08:47 PM
ky
headhunter Offline OP
ky
what plugs brand heat range do you suggest or a stock headed 9.5 to 1 446 with a 88mm? also where do you connect the hoes to the fuel regulator and the blow off valve and waste gate to? can i drill and tap the hat for these? could i run a hose from the hat to a fuel block then off of it to each item?
Re: what do you suggest [Re: headhunter] #720868
06/11/10 10:00 AM
06/11/10 10:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used Autolite AR-72's in my old 440. But I only ran 6psi of boost.
Coming soon!!!!
Re: what do you suggest [Re: headhunter] #720869
06/11/10 11:41 AM
06/11/10 11:41 AM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
The hat will work. Or make yourself a nice manifold for boost reference and connect it to the charge pipe somewhere discrete. I hate hoses hanging everywhere.
