Alternator wiring 1968 Roadrunner
#720507
06/10/10 11:50 AM
06/10/10 11:50 AM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
So I finally got my motor back in and running, now that I figured out the electronic ignition wiring! I am still working out some of the bugs. I put on a new alternator and it appears that it is working but I am not charging the battery. I am assuming that I have either the wrong wire or am missing a wire for the alternator. I guess I should have marked some of the wires when I took the motor out 2 years ago! I really didn't think it was going to take this long. Any suggestions?
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Alternator wiring 1968 Roadrunner
[Re: MoparforLife]
#720509
06/10/10 12:26 PM
06/10/10 12:26 PM
68 Roadrunner
Marcell, MN
It is the dual field alternator.
[Re: 68 Roadrunner]
#720510
06/11/10 01:29 AM
06/11/10 01:29 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
What are the field wires hooked up to? 68 wiring only has one field wire... Previous posts on this subject have said to simply ground one of the two fields and it will charge properly.
[Re: scratchnfotraction]
#720512
06/11/10 09:08 AM
06/11/10 09:08 AM
68 Roadrunner
Marcell, MN
Thanks for all the info guys! I talked to my parts guy and I probably got the wrong alt. It is the one they listed for my car, but the replacement that came in for it only has 1 field terminal. Since I can't get it until Monday I am going to try grounding the other field terminal and see what happens. Thanks again! Great forum!
[Re: 68 Roadrunner]
#720513
06/24/10 09:53 PM
06/24/10 09:53 PM
68 Roadrunner
Marcell, MN
I did run a ground to the other field terminal on the alternator and now it charges great!
