'70 B-body 4-wheel manual drum brake lines #719881
06/09/10 02:18 PM
06/09/10 02:18 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Just curious, does the '70 B-bodies with manual all-drum brakes have the two metering valves like on the disc brake cars or just the one valve below the master cylinder? Anyone have pictures of a finished product for '70?
Thanks..
Troy
PS: Below is from my former '68 Hemi Charger R/T with 4-wheel drum brakes.... Would it be like this?
Troy
Houston Mopar Connection Club
Re: '70 B-body 4-wheel manual drum brake lines [Re: hemi68charger] #719882
06/09/10 02:53 PM
06/09/10 02:53 PM
an8sec70cuda Offline
I'm not sure on a '70 B body in particular, but I know that we have two '69 road runners, one '70 'cuda, and one '71 Demon that all had/have 4 wheel drums. All of them had just the one metering/proportioning valve mounted on the frame below the master cylinder.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: '70 B-body 4-wheel manual drum brake lines [Re: an8sec70cuda] #719883
06/09/10 03:44 PM
06/09/10 03:44 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Just like the picture of your Charger, just 1 prop. valve. Good Luck! Ronnie
Re: '70 B-body 4-wheel manual drum brake lines [Re: hemi68charger] #719884
06/09/10 05:23 PM
06/09/10 05:23 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Yep, just one, if you need one, just pulled one from a 70 this week.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: '70 B-body 4-wheel manual drum brake lines [Re: hemi68charger] #719885
06/09/10 08:43 PM
06/09/10 08:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes
Re: '70 B-body 4-wheel manual drum brake lines [Re: gtx6970] #719886
06/10/10 12:02 AM
06/10/10 12:02 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
How wierd is that....I was going to post the exact same question tonight
CHECK OUT MY NEW WEB SITE !
