paint code?? updat with tag no"s ! #71914
06/12/08 01:22 AM
06/12/08 01:22 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
where do i get paint code info ?
i want to find the original color designation fo my car 1974 dart !
last websights showed options but no paint codes ?
thank you !
Re: paint code?? [Re: calrobb2000] #71915
06/12/08 01:26 AM
06/12/08 01:26 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Try the PPG or Dupont websites and look for their paint chip charts for the older cars.
Re: paint code?? [Re: 68CoronetRT] #71916
06/12/08 01:35 AM
06/12/08 01:35 AM
s. e. pa.
s. e. pa.
hi
i want to know the original color and its factory code , not what color it is now so where on the fender tag is this info ?
thank you !
Re: paint code?? [Re: 68CoronetRT] #71917
06/12/08 01:48 AM
06/12/08 01:48 AM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Third Line
First 3 Letters/Number
Re: paint code?? [Re: DemonKyle] #71918
06/12/08 02:05 AM
06/12/08 02:05 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Third Line
Negative ghostrider!!!
Tag reads as first line is bottom line and should start witha 3 digit "E" code, Second line is next above it and the first three digit code should be your paint code.
Re: paint code?? update ! [Re: RobX4406] #71919
06/12/08 10:00 AM
06/12/08 10:00 AM
s. e. pa.
s. e. pa.
well here are the vin codes ,car has 2 tags ,
starting upper left :
N76 N95 R11 V5X 26 CTD
M21 M25 M26 M31 M38
G11 G52 H51 J25 J52 L31
V1P U B41 G15 C21 C56
JY9 H5LL 000 417 278274
E44 D34 LP23 G48
SECOND TAG :
LI 938
LP23 G4B
so what do i have here ?
thank you !
Re: paint code?? update ! [Re: calrobb2000] #71920
06/12/08 11:08 AM
06/12/08 11:08 AM
OWL
Culvers Offline
Culvers  Offline
OWL
JY9 = Dark Gold Metallic
is there really V1P for vinyl top?
Culvers
Re: paint code?? update ! [Re: Culvers] #71921
06/12/08 11:11 PM
06/12/08 11:11 PM
s. e. pa.
s. e. pa.
hi
j9y - dark gold metalic got it !
anyone feel like decoding all the other ones i posted for this car ?
thank you !
yes V1P is this not normal?
Re: paint code?? update ! [Re: calrobb2000] #71922
06/12/08 11:21 PM
06/12/08 11:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
V1P is not normal, but you have at least one other typo in the codes you listed.
Here is a link to the available 1974 Dodge vinyl tops;
http://www.hamtramck-historical.com/imag...Stripes0002.jpg
If you can post a photo of the tag, that would be better.
Re: paint code?? update ! [Re: Alaskan_TA] #71923
06/13/08 08:35 AM
06/13/08 08:35 AM
s. e. pa.
s. e. pa.
hi
i asure you that the tag IS stamped V1P !
what other code do you think i have wrong ?
trie to poast pict but camera will not take a good clear pic of the tag ???
Re: paint code?? update ! [Re: calrobb2000] #71924
06/14/08 11:08 PM
06/14/08 11:08 PM
s. e. pa.
s. e. pa.
hi
i gues i will never know ?????
Re: paint code?? update ! [Re: calrobb2000] #71925
06/15/08 12:08 AM
06/15/08 12:08 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
hi
Try looking at the back of the tag and check your codes carefully. I think you'll find it.
Keep trying on that pic.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
