Low Mount Alternator bracket for 440- Suggestions?? #719009
06/08/10 10:02 AM
06/08/10 10:02 AM
Pittsburgh, PA
SmokeyBurnout 67 Offline OP
Pittsburgh, PA
We purchased a new Accel 8080 alternator but my low mount bracket used for the mini alternator we had before isnt even close to working. Anyone have suggestions on a low mount bracket that would work on my 440?
Thanks in advance,
Kara
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: SmokeyBurnout 67] #719010
06/08/10 11:08 AM
06/08/10 11:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Kara check on Mancini's website. He may have something available to fix you up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: pittsburghracer] #719011
06/08/10 11:15 AM
06/08/10 11:15 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We custom build them for each application and desired location.Motor plate,elephant ears,stock mounts,right or left location
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: SmokeyBurnout 67] #719012
06/08/10 01:00 PM
06/08/10 01:00 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
marnum HP Greg, 239 513 0750
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: B1KILLER] #719013
06/08/10 02:33 PM
06/08/10 02:33 PM
tboomer Offline
tboomer  Offline
This is what I use...
http://www.dotymi.com/
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: tboomer] #719014
06/08/10 05:44 PM
06/08/10 05:44 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
This is hands down the nicest low mount alternator bracket that I have seen. If the alternator that this bracket was made for is what you are looking for, look no further. Ive seen some peoples custom brackets and they do look nice but not like this part. Most others simply look like a well made home brewed bracket. Just not finished.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: PUNK] #719015
06/08/10 05:59 PM
06/08/10 05:59 PM
Pittsburgh, PA
Pittsburgh, PA
Thanks guys. These low mount bracket are listed for mini alternators. The 8080 Accel I have is not a mini. I appreciate your feedback very much.
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: B G Racing] #719016
06/08/10 06:02 PM
06/08/10 06:02 PM
Pittsburgh, PA
Pittsburgh, PA
Thanks Bob! I was hoping for an over the counter quick fix before the Chrysler race so we can get some testing in. I will let you know. Much appreciated! See ya soon!Can't wait!
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: SmokeyBurnout 67] #719017
06/08/10 06:50 PM
06/08/10 06:50 PM
tboomer Offline
tboomer  Offline
I have a GM one wire on my DMI bracket...Came from an 86 Park Avenue...
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: tboomer] #719018
06/08/10 11:49 PM
06/08/10 11:49 PM
Pittsburgh, PA
Pittsburgh, PA
Thanks tboomer. I am laughing at myself right now...this is what I had on the car with my mini, it's from DMI as well...I bought it from an ebay store last year. It's great, but the darn Accel alt is just too big, the spacing is off. I should have just bought a custom alternator and been done! Thanks so much for the help though, much appreciated.
Post deleted by Defbob [Re: SmokeyBurnout 67] #719019
06/09/10 08:04 AM
06/09/10 08:04 AM
Re: Low Mount Alternator bracket for 440- Suggestions?? #719020
06/09/10 12:50 PM
06/09/10 12:50 PM
Pittsburgh, PA
Pittsburgh, PA
Sweet! I look forward to the pics!!!
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: tboomer] #719021
06/09/10 04:27 PM
06/09/10 04:27 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Same here, mine is the GM 1 wire the mid sized body one...Mid 80's vintage.
Looking at the alternator you have it would be only a matter of custom spacers making the DMI fit, cause the main body looks smaller than mine.
GOOD LUCK
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: tboomer] #719022
06/09/10 04:53 PM
06/09/10 04:53 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
X 2 I use a 90 amp GM 1 wire and integral mini crank trigger mount.
Re: Low Mount Alternator bracket for 440- Suggestions?? [Re: Bigcube] #719023
06/09/10 04:57 PM
06/09/10 04:57 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nother pic, this is the full size MSD pickup, it's a bit tight on my configuration because I need to run a real short belt to keep the alternator away from my frame rails.
