Page 4 of 5 1 2 3 4 5
Re: Are Champion RJ12YC's junk ? [Re: postbody65] #71867
06/16/08 01:06 PM
06/16/08 01:06 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
hi everyone been runing the champions rj12yc which edelbrock recomends but they're getting a rust color on them my specs on my engine are 440 .55 over 11 1/2-1 bme aluminum rods .620 solid roller 6 barrel set up with orange box ignition msd coil and wires never had this color before any help
thanks guys
If you are saying you have a 11.5-1 motor. That is too hot of a plug. You should be in the 9 range. The rust spots are from detontation.
Re: Are Champion RJ12YC's junk ? [Re: BobR] #71868
06/16/08 01:48 PM
06/16/08 01:48 PM
Zebulon
Stationwagonguy Offline
A Closet Buick Man
A Closet Buick Man
Zebulon
Just saving this thread to my favorites for future perusal, ignore me. :lol: I want to remember the autolites and give them a try, the Champions have been driving me insane in my 300 for years, they foul out perpetually, like a bad joke.
[image][/image] Bob SWG '68 Chrysler Town & Country, 'Katy Jo' '70 Chrysler 300 2-door '78 Impala 2-door
Re: Are Champion RJ12YC's junk ? [Re: Viol8r] #71869
06/16/08 07:01 PM
06/16/08 07:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have not had problems using Champion plugs in many applications. However, I have not been able to run that plug (too hot)in either of my two 10:1 CR big blocks.
Re: Are Champion RJ12YC's junk ? [Re: Stationwagonguy] #71870
06/16/08 07:03 PM
06/16/08 07:03 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
The only thing I do with Champion-plugs if I find them anywhere in my engines or garage, is to toss them as hard and far away as possible.
I'm using Accel-plugs in every bigblock I have, 'cept the Eddy-headed stroker motor I run now, and never had any problems with them whatsoever.
Heck, I can't even remember when the last time was I replaced a set of these yellow buggers in an engine anymore.
Why Accels?
Well next to their immaculate state of operation, the price is also right. I get them kinda for free.
Re: Are Champion RJ12YC's junk ? #71871
06/16/08 07:44 PM
06/16/08 07:44 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
well add some ACETONE and it will cure your plug problems...
LOL!!!!!
really- I prefer running the Champ surface gap plugs-like the ones for marine applications alsop same upgrades for the vipers but short reach.
oh and never run a resirtor plug in a high comp engine, as the cyl press gets higher the spark has more resistance to jump the gap-so as the gap resistance increases so does the series resistance of the plugs resistor and wire resistance to a point ehere you can loose 1/2 your spark power in the wire and plug alone.
simple balanced bridge ohm law with a littke dielectric constant throen in
Re: Are Champion RJ12YC's junk ? [Re: HemiGreg] #71872
06/16/08 11:17 PM
06/16/08 11:17 PM
LOL!!!!!
of which the masses do not seem to comprehend that fact. they spend a billion dollars on
parts, a fail to see the suttle nuances of what makes a plug fire under certain conditions.
Re: Are Champion RJ12YC's junk ? [Re: GTX MATT] #71873
06/17/08 11:07 PM
06/17/08 11:07 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Has anyone used the Autolite 75's instead of the rj12yc?
These are listed as a non-resistor replacement for the Autolite 85's.
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71874
06/17/08 11:08 PM
06/17/08 11:08 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Anyone know if the j63's by Champion are a 3/8" reach plug?
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71875
06/17/08 11:11 PM
06/17/08 11:11 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Can anyone tell me what the difference is between the resistor style and non-resistor style spark plugs?
I am confused as to what that actually means,if this is in the wrong section ,please let me know!
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71876
06/17/08 11:17 PM
06/17/08 11:17 PM
non-resistor plug has a solid core.
resitor plug has a wire coil and a gap inside it.
Re: Are Champion RJ12YC's junk ? #71877
06/18/08 08:31 AM
06/18/08 08:31 AM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Bottom of the pile in my opinion. I did testing back in my racing days and Champion had the most resistance of all the plugs tested. NGKs tested the best.
Re: Are Champion RJ12YC's junk ? [Re: 6T9Hemi] #71878
06/18/08 10:21 AM
06/18/08 10:21 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Given the limited use of my GTX, several years ago when it had iron heads I used to be able to get at least two seasons of use out of a set of Champions and they were rj12yc. After that, I would change them because they were rusty on the outside, not because they weren't firing.
In the 13 or so years I ran that same iron head 440, I never had a problem with the spark plugs that I couldn't blame on fuel delivery or another part of the ignition.
Some applications might have some magic or voodoo in spark plug selection, but I've never seen it. A spark plug either fires properly every time, or it doesn't. It's either the right heat range, or it isn't.
Rich H.
Esse Quam Videri
Re: Are Champion RJ12YC's junk ? [Re: ZIPPY] #71879
06/18/08 11:31 AM
06/18/08 11:31 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Just had a 2000 maxima today come in, it was shakeing at idle and kept sending cylinder 2 missfire and random misfire codes. Guy had recently done a tune-up and so I didn't look at the plugs first. I checked all the conectors and coils and such and nothing fixed it, finally I pulled the plugs and the center electrode on number 2 had fallen out of the plug! I quickly threw in an old plug laying around the shop and it was still shakeing but not sending misfire codes. Ordered a new set of NGKs and it was smoothe as glass. The plugs he had put in just a few miles earlier were... drum roll... bosche platnium crap plugs! I have seen this exact scenario, except the electrode falling out, over and over and over. Some one will put in bosche plugs and make there car run worse. Never seen this problem from any other plugs.
Re: Are Champion RJ12YC's junk ? [Re: 6packattk] #71880
06/18/08 12:09 PM
06/18/08 12:09 PM
Connecticut
LL340Rag Offline
LL340Rag  Offline
Connecticut
They are really hard to find but the only plug I have never had a problem with is a Nippondenso. I run them in everything from my lawn mower, mopars, Volkswagon and BMW's. I haven't had a foul out in years even running a 2 two stroke mix in a 4 stoke mower (I ran out of gas).
Re: Are Champion RJ12YC's junk ? [Re: LL340Rag] #71881
06/18/08 01:06 PM
06/18/08 01:06 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I run RN12's IIRC in my 360, never had a problem with champion plugs, ever. my bike ran rougher with bosch's than it did with the OEM champions.
2017 Grand Cherokee Overland
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71882
06/18/08 03:11 PM
06/18/08 03:11 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
Champions never seemed to last very long in Mopar big blocks, I gave up on them in the late 70's...
'69 Plymouth GTX
See you on the street...
Re: Are Champion RJ12YC's junk ? [Re: BobR] #71883
06/20/08 03:11 PM
06/20/08 03:11 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
NOOOOO!!! NOT Budweiser! how can you think of even drinking that bitter clydesdale p!$$?? Remember that beer commercial from a couple years back, where the players in the commercial all puckered up after taking a swig of "bitter beer"? MILLER MAKES BETTER BEER and BETTER WELDERS TOO! Budweiser=
Re: Are Champion RJ12YC's junk ? [Re: mark7171] #71884
08/21/08 11:10 AM
08/21/08 11:10 AM
Port Reading, NJ
roadrunner7070 Offline
Port Reading, NJ
champion has not made j11y's, superseeded by RJ12YC
all have resistors now.
J12Y's are a hotter plug and not the same as J11Y's.
Re: Are Champion RJ12YC's junk ? [Re: craigerlitz] #71885
08/21/08 11:42 AM
08/21/08 11:42 AM
Northern Indiana
capac Offline
capac  Offline
Northern Indiana
I would'nt give you a nickel for a new
champion plug..
Use AutoLite.... or AC Delco...
Funny, I wouldn't give you a penny for a set of autolites. Never had any luck with them in a 2.5L, 3.9L, 318, 360, or 440. I'll stick with the Champions.
Autolites won't even last 1 week in my 383. Thought I would save a buck, but back to champions it was. Maybee the manufacture did know something....
'64 390 Valiant Signet Convertable (WIP...)
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71886
08/22/08 02:43 PM
08/22/08 02:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
This reply is freakin hilarious:
um.. wrong. you can still get non-resistor champions all-day-long.
where?
earth
no wonder autozone doesnt have them.
hard to find but you still can find them down here in Venezuela... in fact what is really imposible is try to get them with resistor.
about plug itself. I have no claim with them... just one failed in 8 years. maybe better performance in others, yes, but they work just fine on any street car as they were mounted from factory purpuose.
