Re: Front Spring Hanger same on 71, 72 B-body as 73, 74
[Re: 397STROKER]
#718564
06/09/10 12:07 AM
06/09/10 12:07 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
74 is the exception... they used a smaller bolt to fit a thicker isolator on front bushing, so the hole is smaller.
however the fitment on body is exactly the same in all 71/74
[Re: 397STROKER]
#718566
06/09/10 06:00 PM
06/09/10 06:00 PM
NachoRT74
Valencia, España
well, not in my case or several I have seen. Ovals are Station wagons and maybe sedans too I think then also C bodies if you get a 74 bracket you simply can enlarge the hole to fit on earliers, and will be done. Backwards will be moslty sure harder to do. I will be needing a 74 bracket pretty soon BTW.
[Re: Mr_fixit]
#718568
06/10/10 01:02 AM
06/10/10 01:02 AM
NachoRT74
Valencia, España
well not in my case... who knows why. ( beside mine was assemblied in Venezuela, not in USA )
whatever is the reason, go for the sure side and get 71/73s
