trans issues #718466
06/07/10 07:48 PM
06/07/10 07:48 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
Shifting from 1st to 2nd at 6500 it doesn't shift until 7500 very harsh. Checked shift linkage, fresh rebuild.Possible valve body ? it is a reverse manual
Re: trans issues [Re: dart443] #718467
06/08/10 01:03 PM
06/08/10 01:03 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Is the valvebody a low band apply unit in 1st? What brand, model? If so, sounds like a 1-2 problem with the low/rev band release - kickdown band apply. If not, the only component that applies during the 1-2 is the kickdown band. Not too many things to check.
