ok,how do you set one up???
stock 78 440 from a motorhome
650 spredbore mech double pumper carb
stock spredbore intake
center dump mannys
stock 727 with stock TC..full manual vb
8 3/4 with 3.91s
88 short bed truck
once its in hand,I pull the points dist out,drop in the duel point dist with mech advance only
set timeing to same setting as it is now with the single points?
what else do you do to dial it in?
does it need a speical coil to go with it
any gain going with the duel points over a single set?
need some skoolin on the how to set it correctly
or do I even need it??
what advantage does it have performance wize over a single set
no I dont want elect mopar dist
