Page 2 of 5 1 2 3 4 5
Re: Are Champion RJ12YC's junk ? [Re: mopowergtx] #71827
06/12/08 09:17 AM
06/12/08 09:17 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Heres a link to the new non-resistor Champion comparable to the old J11Y, the C at the end is for Copper and thats pretty much the same heat range. Now I've never run them just saying they are out there, on planet earth. And the new ones quality compared to the old(60's-70's) is unknow personally by me from experience.
J12YC Champions
Re: Are Champion RJ12YC's junk ? [Re: mopowergtx] #71828
06/12/08 09:23 AM
06/12/08 09:23 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Yep Champions are junk, thats why they were the OE plug when these cars were new. I think your problem is running a resistor plug in that motor in the first place. Find a non-resistor plug in the heat range you want and try that. I run old NOS J11Y Champions and have never had a problem. But you pick any manufacture you want and find out for yourself which one you like because anytime somebody asks about spark plugs on here you get a different answer. Its about like asking which beer is the best.
the champions that were installed in the 60's/70's are a much better plug than the new champions , never had good luck running that rj12 in anything either .
Probably right John, but I still got 4 sets of the vintage NOS J11Y's left.
But I still have never seen anybody have any real luck running a resistor plug on a beefed up mill running alot squeeze and a hot ignition. Seems like whatever brand they run the stupid resistors burn out of them with quick.
i have a few NOS sets of 11's and 10's .
maybe its the resistor but i never had luck wit hthem on stock performance big blocks . my dart had a set of them on it when i got it , it was the first thing i swapped out .
Re: Are Champion RJ12YC's junk ? [Re: mopowergtx] #71829
06/12/08 09:41 AM
06/12/08 09:41 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
what about suppressor plugs?
Re: Are Champion RJ12YC's junk ? [Re: mark7171] #71830
06/12/08 10:14 AM
06/12/08 10:14 AM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
What would be the best plug to run in a 340 with 11.5:1 and solid lift w/mallory hyfire VI-AL ignition?
Just getting ready to fire it up and want to make sure I get the best plug. Also isn't the gap supposed to be .040-.045 with the hot ignition modules?
Re: Are Champion RJ12YC's junk ? [Re: W5Duster436] #71831
06/12/08 10:55 AM
06/12/08 10:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I swapped from Champs to Autolites a few years back. I really didn't notice much of a difference except that the Auto's seem to get rustier quicker. People swear by them.
Re: Are Champion RJ12YC's junk ? [Re: Mr.Yuck] #71832
06/12/08 11:01 AM
06/12/08 11:01 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Are Champion RJ12YC's junk ? [Re: mopars4ever] #71833
06/12/08 11:21 AM
06/12/08 11:21 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I ran Splitfires on my slant and she loved it, Ran Bosch Plat's on the 70 R/T 440 and she stumbled, took her back to Champions and she ran like a champ....I currently have Champions in the 69 R/T now and have 12YC spares. They seem work just right with my combo....with the 509, eddy, dual quads and a hotter cam I am going with NGK
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Are Champion RJ12YC's junk ? [Re: mopars4ever] #71834
06/12/08 11:22 AM
06/12/08 11:22 AM
O
OLD318 Offline
OLD318  Offline
O
I would'nt give you a nickel for a new
champion plug..
Use AutoLite.... or AC Delco...
Re: Are Champion RJ12YC's junk ? [Re: 451Mopar] #71835
06/12/08 11:29 AM
06/12/08 11:29 AM
usa
mrmopardan Offline
mrmopardan  Offline
usa
My favorate is the NGK V-Power, and they are fairly inexpensive too.
Tried them all. I will use nothing else but NGK's
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71836
06/12/08 12:18 PM
06/12/08 12:18 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
I switched from Champion N9YC to NGK BP6ES on my fairly stout 360 and there was a substantial improvement. I'm also running an MSD 6AL and IIRC MSD specifically recommends AGAINST running platinum plugs. I'm not sure if that is true with any other aftermarket ignition systems.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Are Champion RJ12YC's junk ? [Re: W5Duster436] #71837
06/12/08 07:34 PM
06/12/08 07:34 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Yes! Always run a larger gap with the ignition box systems. I do on my drag car and it works great. Hard to reccomend a specific plug though because ask 5 different people and get 5 different answers...
Re: Are Champion RJ12YC's junk ? [Re: MadMatt] #71838
06/12/08 08:31 PM
06/12/08 08:31 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Good advice. Don't use platinums with MSD. The 12 heat range plug is too hot for 12.5-1 compression. You need the 9 series equivalent or cooler. I also like NGK or Autolite racing with the strap cut back. If you foul a 9 series plug you have some tuning issues. I recommend an Autolite AR23. -Bob
Re: Are Champion RJ12YC's junk ? [Re: OLD318] #71839
06/12/08 10:54 PM
06/12/08 10:54 PM
Pennsylvania
craigerlitz Offline
craigerlitz  Offline
Pennsylvania
champion plug..
Funny, I wouldn't give you a penny for a set of autolites. Never had any luck with them in a 2.5L, 3.9L, 318, 360, or 440. I'll stick with the Champions.
Re: Are Champion RJ12YC's junk ? [Re: craigerlitz] #71840
06/12/08 10:58 PM
06/12/08 10:58 PM
i wonder which has more ZDDP (zinc) content.. champions or autolites?
Re: Are Champion RJ12YC's junk ? #71841
06/12/08 11:20 PM
06/12/08 11:20 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I don't know but I do know that every racer I'm involved with either uses Autolite racing plugs or NGK's. -Bob
Re: Are Champion RJ12YC's junk ? [Re: BobR] #71842
06/12/08 11:28 PM
06/12/08 11:28 PM
personal preference i guess. if one finds a plug that works well, no reason not to use it.
Re: Are Champion RJ12YC's junk ? [Re: BobR] #71843
06/13/08 12:54 AM
06/13/08 12:54 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Thanks Bob,Do I have to cut the strap back?
Re: Are Champion RJ12YC's junk ? #71844
06/13/08 10:35 AM
06/13/08 10:35 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
And everybody knows Budweiser in the bottle is the best beer out there.
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71845
06/13/08 10:57 AM
06/13/08 10:57 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The AR23 plugs come this way OOTB. -Bob
Re: Are Champion RJ12YC's junk ? [Re: BobR] #71846
06/13/08 11:10 AM
06/13/08 11:10 AM
CHRGR69 Offline
CHRGR69  Offline
I always find a set of NOS Mopar/Champion plugs for the big blocks on Ebay. They work fine. Maybe its because they are NOS!
Grandma always said I had "hands of gold"!
