will a 73 charger steering gear box fit a 72? #718265
06/07/10 12:54 PM
06/07/10 12:54 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
Having a tough time in finding a steering gear box locally for my 72 charger, they have them for a 73 all day long. will a 73 fit in my 72?
Re: will a 73 charger steering gear box fit a 72? [Re: AK_JH27] #718266
06/07/10 12:58 PM
06/07/10 12:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it will physically fit , but you may need a new pitamn arm , more than likely you will , the size of the output sector gear changed for most of the model line with the 73 model year. It should be an easy switch over on a B body requiring only the pitman arm ... but I could be wrong on ONLY the pitman arm .
You will not find a 72 down size box unless you get REAL lucky ...
Re: will a 73 charger steering gear box fit a 72? [Re: AK_JH27] #718267
06/07/10 01:00 PM
06/07/10 01:00 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The steering chuck, whether power or manual physically interchange for many many years. I put a Diplomat Cop car chuck in my 74 Duster. The pitman arms may have to change in your case.
Re: will a 73 charger steering gear box fit a 72? [Re: AK_JH27] #718268
06/07/10 01:03 PM
06/07/10 01:03 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Different part numbers and it looks like the spline for the pitman arm is bigger on the 73. You might be able to swap arms but Rockauto has both years.
72 & 73
My
Own
Personal
Adrenaline
Rush
Re: will a 73 charger steering gear box fit a 72? [Re: Moparzrule] #718269
06/07/10 01:09 PM
06/07/10 01:09 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
I just checked with Rockauto they said i have to ship my unit to them and they ship it to get repaired. dont want to go this route. Napa here has a 73 in stock, hence no shipping charges, I'll go buy it with a new pitman arm and try it.
