Page 1 of 5 1 2 3 4 5
Are Champion RJ12YC's junk ? #71807
06/12/08 12:13 AM
06/12/08 12:13 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
I just installed a new set of Champion rj12yc spark plugs which I have been using for years and THREE are fouled out.Is there a better plug for a hot 383?Here's the combo:
.030 12.5-1 trw dome(heavy slugs)
free floating pins
zero deck block
906 78cc heads(bowl blended)
6-barrel setup(promax base plates)
509,soon to be racer brown sth-42 cam
msd ign.
4-speed
4.10-1 gear
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71808
06/12/08 12:26 AM
06/12/08 12:26 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
yes, them champions are junk, my truck wasnt getting any fire at all with them and its a bone stock 400. i switched to bosch platinums and it runs like a champ now.
Re: Are Champion RJ12YC's junk ? [Re: 72d100] #71809
06/12/08 01:00 AM
06/12/08 01:00 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
There are a sea of spark plugs out there and I don't know the differences,I just want a good plug to run in my combo.There are platinum tipped,double platinum tipped,v-power,irridium,non-resistor,resistor,and Jegs carries the plugs without a j-strap,whatever that means!
Someone please enlighten me!Thanks,John
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71810
06/12/08 01:21 AM
06/12/08 01:21 AM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
I've always run # 85 Autolites in all my big blocks. They work great.
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71811
06/12/08 04:34 AM
06/12/08 04:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My favorate is the NGK V-Power, and they are fairly inexpensive too.
Re: Are Champion RJ12YC's junk ? [Re: 451Mopar] #71812
06/12/08 06:24 AM
06/12/08 06:24 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Champions in the new Mopars and Autolites in the old.Ive never seen a Bosch plug run good in anything yet.Ive changed thousands at work because they are crap and cars run bad with them.If you got a car to run good with them go buy a lottery ticket.Rocky
Chrysler Firepower
Re: Are Champion RJ12YC's junk ? [Re: therocks] #71813
06/12/08 06:41 AM
06/12/08 06:41 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
Autolite and NGK, the platnums work great
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71814
06/12/08 06:46 AM
06/12/08 06:46 AM
This may not be any help but I have found the Champions to work well in stock small blocks and Autolites to work well in stock big blocks. Being a non-stock six-pack may require something different.
Re: Are Champion RJ12YC's junk ? [Re: GTX70sixpack] #71815
06/12/08 06:48 AM
06/12/08 06:48 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
what the scoop on E plugs?
Re: Are Champion RJ12YC's junk ? [Re: BigTerry] #71816
06/12/08 08:25 AM
06/12/08 08:25 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Yep Champions are junk, thats why they were the OE plug when these cars were new. I think your problem is running a resistor plug in that motor in the first place. Find a non-resistor plug in the heat range you want and try that. I run old NOS J11Y Champions and have never had a problem. But you pick any manufacture you want and find out for yourself which one you like because anytime somebody asks about spark plugs on here you get a different answer. Its about like asking which beer is the best.
Re: Are Champion RJ12YC's junk ? [Re: BigTerry] #71817
06/12/08 08:26 AM
06/12/08 08:26 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
i use the rj12yc's in the 440, it runs fine. my 5/8" 440 plug is the bosch HR8BPX . i remove the tapper on a lathe.
the autolite 9323's, in the 318 with great results and a 5/8" plug.
Re: Are Champion RJ12YC's junk ? [Re: mopowergtx] #71818
06/12/08 08:30 AM
06/12/08 08:30 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
champion has not made j11y's, superseeded by RJ12YC
all have resistors now.
Re: Are Champion RJ12YC's junk ? [Re: mark7171] #71819
06/12/08 08:38 AM
06/12/08 08:38 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Standard Autolite copper in my 340 and it runs strong.
Re: Are Champion RJ12YC's junk ? [Re: mark7171] #71820
06/12/08 08:41 AM
06/12/08 08:41 AM
um.. wrong. you can still get non-resistor champions all-day-long.
Re: Are Champion RJ12YC's junk ? #71821
06/12/08 08:47 AM
06/12/08 08:47 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
where?
Re: Are Champion RJ12YC's junk ? [Re: mark7171] #71822
06/12/08 08:50 AM
06/12/08 08:50 AM
where?
earth
Re: Are Champion RJ12YC's junk ? #71823
06/12/08 08:52 AM
06/12/08 08:52 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
no wonder autozone doesnt have them.
Re: Are Champion RJ12YC's junk ? [Re: mopowergtx] #71824
06/12/08 08:56 AM
06/12/08 08:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the champions that were installed in the 60's/70's are a much better plug than the new champions , never had good luck running that rj12 in anything either .
Re: Are Champion RJ12YC's junk ? [Re: JohnRR] #71825
06/12/08 09:04 AM
06/12/08 09:04 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Probably right John, but I still got 4 sets of the vintage NOS J11Y's left.
But I still have never seen anybody have any real luck running a resistor plug on a beefed up mill running alot squeeze and a hot ignition. Seems like whatever brand they run the stupid resistors burn out of them with quick.
Re: Are Champion RJ12YC's junk ? [Re: jcastle1] #71826
06/12/08 09:13 AM
06/12/08 09:13 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Autolites for me
