Re: Are Champion RJ12YC's junk ?
[Re: postbody65]
#71867
06/16/08 01:06 PM
06/16/08 01:06 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
hi everyone been runing the champions rj12yc which edelbrock recomends but they're getting a rust color on them my specs on my engine are 440 .55 over 11 1/2-1 bme aluminum rods .620 solid roller 6 barrel set up with orange box ignition msd coil and wires never had this color before any help thanks guys
If you are saying you have a 11.5-1 motor. That is too hot of a plug. You should be in the 9 range. The rust spots are from detontation.
[Re: BobR]
#71868
06/16/08 01:48 PM
06/16/08 01:48 PM
Posts: 803 Zebulon
Stationwagonguy
A Closet Buick Man
A Closet Buick Man
Zebulon
Just saving this thread to my favorites for future perusal, ignore me. :lol: I want to remember the autolites and give them a try, the Champions have been driving me insane in my 300 for years, they foul out perpetually, like a bad joke.
[image][/image]
Bob
SWG
'68 Chrysler Town & Country, 'Katy Jo'
'70 Chrysler 300 2-door
'78 Impala 2-door
[Re: Viol8r]
#71869
06/16/08 07:01 PM
06/16/08 07:01 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
I have not had problems using Champion plugs in many applications. However, I have not been able to run that plug (too hot)in either of my two 10:1 CR big blocks.
[Re: Stationwagonguy]
#71870
06/16/08 07:03 PM
06/16/08 07:03 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
The only thing I do with Champion-plugs if I find them anywhere in my engines or garage, is to toss them as hard and far away as possible. I'm using Accel-plugs in every bigblock I have, 'cept the Eddy-headed stroker motor I run now, and never had any problems with them whatsoever. Heck, I can't even remember when the last time was I replaced a set of these yellow buggers in an engine anymore. Why Accels? Well next to their immaculate state of operation, the price is also right. I get them kinda for free.
#71871
06/16/08 07:44 PM
06/16/08 07:44 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
well add some ACETONE and it will cure your plug problems... LOL!!!!! really- I prefer running the Champ surface gap plugs-like the ones for marine applications alsop same upgrades for the vipers but short reach. oh and never run a resirtor plug in a high comp engine, as the cyl press gets higher the spark has more resistance to jump the gap-so as the gap resistance increases so does the series resistance of the plugs resistor and wire resistance to a point ehere you can loose 1/2 your spark power in the wire and plug alone. simple balanced bridge ohm law with a littke dielectric constant throen in
[Re: HemiGreg]
#71872
06/16/08 11:17 PM
06/16/08 11:17 PM
of which the masses do not seem to comprehend that fact. they spend a billion dollars on parts, a fail to see the suttle nuances of what makes a plug fire under certain conditions.
[Re: jcastle1]
#71876
06/17/08 11:17 PM
06/17/08 11:17 PM
non-resistor plug has a solid core. resitor plug has a wire coil and a gap inside it.
[Re: 6T9Hemi]
#71878
06/18/08 10:21 AM
06/18/08 10:21 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Given the limited use of my GTX, several years ago when it had iron heads I used to be able to get at least two seasons of use out of a set of Champions and they were rj12yc. After that, I would change them because they were rusty on the outside, not because they weren't firing.
In the 13 or so years I ran that same iron head 440, I never had a problem with the spark plugs that I couldn't blame on fuel delivery or another part of the ignition.
Some applications might have some magic or voodoo in spark plug selection, but I've never seen it. A spark plug either fires properly every time, or it doesn't. It's either the right heat range, or it isn't.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#71879
06/18/08 11:31 AM
06/18/08 11:31 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Just had a 2000 maxima today come in, it was shakeing at idle and kept sending cylinder 2 missfire and random misfire codes. Guy had recently done a tune-up and so I didn't look at the plugs first. I checked all the conectors and coils and such and nothing fixed it, finally I pulled the plugs and the center electrode on number 2 had fallen out of the plug! I quickly threw in an old plug laying around the shop and it was still shakeing but not sending misfire codes. Ordered a new set of NGKs and it was smoothe as glass. The plugs he had put in just a few miles earlier were... drum roll... bosche platnium crap plugs! I have seen this exact scenario, except the electrode falling out, over and over and over. Some one will put in bosche plugs and make there car run worse. Never seen this problem from any other plugs.
[Re: LL340Rag]
#71881
06/18/08 01:06 PM
06/18/08 01:06 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I run RN12's IIRC in my 360, never had a problem with champion plugs, ever. my bike ran rougher with bosch's than it did with the OEM champions.
[Re: mark7171]
#71884
08/21/08 11:10 AM
08/21/08 11:10 AM
Posts: 2,640 Port Reading, NJ
roadrunner7070
Port Reading, NJ
champion has not made j11y's, superseeded by RJ12YC
all have resistors now.
J12Y's are a hotter plug and not the same as J11Y's.
