Converted to electronic ignition now doesn't charge
#717957
06/06/10 10:11 PM
06/06/10 10:11 PM
Posts: 661 Iowa
jon01
Iowa
Car is a 68 Coronet. Simply installed an orange box and corresponding distributor. Charged fine before, now nothing. Double checked connections at the alternator, bulkhead and voltage regulator. Where should I start troubleshooting?
Thanks guys!
68 Charger R/T - #'s matching car, 499/727/3.91
Re: Converted to electronic ignition now doesn't charge
[Re: jon01]
#717958
06/06/10 11:11 PM
06/06/10 11:11 PM
RapidRobert
turn ign sw to "on" and w your VOM see if you have fire @ the VR and to the green wire at the alt field terminal. OE 68 type VR and single field terminal alt I am assuming.
