4.10 or 4.56 gears for a 8-3/4 rearend
#717942
06/06/10 09:52 PM
06/06/10 09:52 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
well my push rods are so posed to be here tomorrow. so that means i have to get off my butt and start building my 73 dart again. I have to take the 4.10 gears out and set them up right. so i was wondering if i should leave the 4.10 in it or go to the 4.56 gears. I have both sets of gears already so i wont be out any money. here is a little run down on my car. 1973 dodge dart weighs around 3400 11.1.1 440 Indy EZ heads flow 310-315 @ 600 lift comp solid roller 264@ 0.50 and 634 lift mopar m1 tunnel ram 2 750 carter carbs 727 with 10 inch turbo action 3800-4200 stall M/T 275/60/15 drag radials.
I was thinking about using the 4.56 because i don't have enough converter right now.would the 4.56 make up the difference for the mismatched converter? look forward to your answers.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: 4.10 or 4.56 gears for a 8-3/4 rearend
[Re: mopar65]
#717943
06/06/10 10:01 PM
06/06/10 10:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If its a race car 4.56 at least but you already answered your question
[Re: MR_P_BODY]
#717944
06/06/10 10:10 PM
06/06/10 10:10 PM
Posts: 2,177 ill
dennismopar73
ill
[Re: dennismopar73]
#717945
06/06/10 10:17 PM
06/06/10 10:17 PM
mopar65
wow that was easy thanks for the help Mopar65 ok that did not take very long on to the next question.with the 275/60/15 tires what would my trap rpms be with the 4.10 and the 4.56 gears?
support our troops
[Re: mopar65]
#717946
06/06/10 10:19 PM
06/06/10 10:19 PM
BradH
1/8th or 1/4 mile? I run the same size tire w/ 4.10s and a converter that has about 7-8% slippage... it's spinning 6800+ through the traps at 125+ MPH in the 1/4.
Given the mid-range that a tunnel ram could have, you may not be as far off as you think w/ your current converter.
EDIT: Assuming 4.56s don't cause the engine to over-rev and actually lose MPH on the big end, they'd add another 400+ RPM on top of what 4.10s would turn.
[Re: BradH]
#717947
06/06/10 10:34 PM
06/06/10 10:34 PM
mopar65
sorry about that. my home track will probably only let me run 1/8 to 1000 foot. but when i go to monster mopar or nor walk which are 1/4. i was wondering if the 4.56 would be to much gear for me. the 10 inch was for the other 440 i had in the dart that i never got to use and is going to have to do for now. Dewayne said to get a 5200 stall converter. which i plan to do but just not right now.i might just stay with the 4.10 but i wanted to see what you guys would say that are a lot smarter than me.thanks mopar65
support our troops
[Re: mopar65]
#717950
06/06/10 11:05 PM
06/06/10 11:05 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
My Valiant with a 440, 4.10's and a 275 radial traps at 6,100. I only shift it at 5,500 though. It doesn't go any quicker shifting higher, lol.
[Re: mopar65]
#717951
06/07/10 12:13 AM
06/07/10 12:13 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
the way I see it Bobby its only a 28" tire..if you were going to 31" or taller then I'd say go with the 4.56...forgot to say thats for 1/4 mile..
[Re: mopar65]
#717955
06/08/10 01:27 PM
06/08/10 01:27 PM
Posts: 1,118 Central Missouri - USA
Ramcharger
super gas
super gas
Another vote for 4.10. Using Randy's Ring & Pinion RPM calculator (I'd say the slippage % is pretty low): 4.10 - 28" tire - 125mph = 6315 rpm 4.56 - 28" tire - 125mph = 7023 rpm 4.10 - 28" tire - 130mph = 6567 rpm 4.56 - 28" tire - 130mph = 7304 rpm Your new engine probably has more RPM potential than I would feel confortable with using a semi-stock (internal pickup) oiling system. It will live a bunch longer if you keep the RPMs under 7000. Just my
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop) '99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54 '89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift '14 Dodge Dart Limited 2.4/6-speed A/T
