4.10 or 4.56 gears for a 8-3/4 rearend #717942
06/06/10 09:52 PM
06/06/10 09:52 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
well my push rods are so posed to be here tomorrow. so that means i have to get off my butt and start building my 73 dart again. I have to take the 4.10 gears out and set them up right. so i was wondering if i should leave the 4.10 in it or go to the 4.56 gears. I have both sets of gears already so i wont be out any money. here is a little run down on my car.
1973 dodge dart weighs around 3400
11.1.1 440
Indy EZ heads flow 310-315 @ 600 lift
comp solid roller 264@ 0.50 and 634 lift
mopar m1 tunnel ram 2 750 carter carbs
727 with 10 inch turbo action 3800-4200 stall
M/T 275/60/15 drag radials.
I was thinking about using the 4.56 because i don't have enough converter right now.would the 4.56 make up the difference for the mismatched converter? look forward to your answers.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717943
06/06/10 10:01 PM
06/06/10 10:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
11.1.1 440
If its a race car 4.56 at least but you already
answered your question
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: MR_P_BODY] #717944
06/06/10 10:10 PM
06/06/10 10:10 PM
ill
dennismopar73 Offline
ill
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: dennismopar73] #717945
06/06/10 10:17 PM
06/06/10 10:17 PM
mopar65 Offline OP
mopar65  Offline OP
wow that was easy thanks for the help Mopar65
ok that did not take very long on to the next question.with the 275/60/15 tires what would my trap rpms be with the 4.10 and the 4.56 gears?
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717946
06/06/10 10:19 PM
06/06/10 10:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
1/8th or 1/4 mile? I run the same size tire w/ 4.10s and a converter that has about 7-8% slippage... it's spinning 6800+ through the traps at 125+ MPH in the 1/4.
Given the mid-range that a tunnel ram could have, you may not be as far off as you think w/ your current converter.
EDIT: Assuming 4.56s don't cause the engine to over-rev and actually lose MPH on the big end, they'd add another 400+ RPM on top of what 4.10s would turn.
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: BradH] #717947
06/06/10 10:34 PM
06/06/10 10:34 PM
mopar65 Offline OP
mopar65  Offline OP
sorry about that. my home track will probably only let me run 1/8 to 1000 foot. but when i go to monster mopar or nor walk which are 1/4. i was wondering if the 4.56 would be to much gear for me. the 10 inch was for the other 440 i had in the dart that i never got to use and is going to have to do for now. Dewayne said to get a 5200 stall converter. which i plan to do but just not right now.i might just stay with the 4.10 but i wanted to see what you guys would say that are a lot smarter than me.thanks mopar65
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717948
06/06/10 10:38 PM
06/06/10 10:38 PM
BradH Offline
BradH  Offline
Keep the 4.10s. I don't see your combination benefiting from any more gear given the short tires.
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717949
06/06/10 10:53 PM
06/06/10 10:53 PM
ill
ill
456 is the gear
only one better would be 430 s
j m o
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717950
06/06/10 11:05 PM
06/06/10 11:05 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
My Valiant with a 440, 4.10's and a 275 radial traps at 6,100. I only shift it at 5,500 though. It doesn't go any quicker shifting higher, lol.
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717951
06/07/10 12:13 AM
06/07/10 12:13 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
the way I see it Bobby its only a 28" tire..if you were going to 31" or taller then I'd say go with the 4.56...forgot to say thats for 1/4 mile..
383man [Re: Dart1031] #717952
06/07/10 12:15 AM
06/07/10 12:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What I wonder is if it is tubbed or wheel wells stretched ?? If not you really cant fit a very tall tire under it. If so I would stick with the 4.10's. 4.10's with a 28" tire work good. You may not be able to fit any taller then a 28" tire under it. Ron
Re: 383man [Re: 383man] #717953
06/07/10 12:24 AM
06/07/10 12:24 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Sell them both and run 3.91 gear. The 440 has more then enough low end grunt (even with the tunnel ram) to move you down the track. If you go to low on the gear selection you will over power the tire. I have run 4.30 , 4.10 and then 3.91 and it went faster with lower ET with each change. This is with 28" tire A body. Why spin a motor higher then you have to to get the same results. ....Phill
Re: 383man [Re: 9 Sec Phill] #717954
06/07/10 01:15 AM
06/07/10 01:15 AM
4:10 Like Phil said them 440 don't need no stinking low gears, them be BB
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717955
06/08/10 01:27 PM
06/08/10 01:27 PM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
Another vote for 4.10.
Using Randy's Ring & Pinion RPM calculator (I'd say the slippage % is pretty low):
4.10 - 28" tire - 125mph = 6315 rpm
4.56 - 28" tire - 125mph = 7023 rpm
4.10 - 28" tire - 130mph = 6567 rpm
4.56 - 28" tire - 130mph = 7304 rpm
Your new engine probably has more RPM potential than I would feel confortable with using a semi-stock (internal pickup) oiling system. It will live a bunch longer if you keep the RPMs under 7000.
Just my
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: 4.10 or 4.56 gears for a 8-3/4 rearend [Re: mopar65] #717956
06/08/10 02:39 PM
06/08/10 02:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run 4.11`s in my dart w/a Hoosier QTP 29x13.5 steeet tire and love the way it runs at the track and more importantly how it drives on the street.....1.36 60`s at the track and I can drive it on the fwy for miles on end. Best of both worlds.
