Re: Car stalls under rapid braking
[Re: Blues_Cuda]
#71753
06/12/08 11:00 AM
06/12/08 11:00 AM
Posts: 571 Western NC
68Bullit
Western NC
Are you running a Carter / Edelbrock carb?
Holley #4150 650DP
[Re: 68Bullit]
#71756
06/12/08 06:18 PM
06/12/08 06:18 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
Holley #4150 650DP
OK. The reason I asked is that the AFB style carbs tend to act like that. Our Max Wedge Savoy does the same thing on the street during aggressive braking and even on the shorter shutdown areas at the mom & pop racetracks.
As mentioned above, try the jet extensions and maybe a vent tube baffle on the Holley.
[Re: Paul_Fancsali]
#71759
06/12/08 09:11 PM
06/12/08 09:11 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
my guess was going to be float level too high, flooding the engine. How does it act on restart? Does it light off instantly, or do you have to crank it a little to catch?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Classof70Chally]
#71761
06/13/08 08:26 AM
06/13/08 08:26 AM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
No, sorry, I'm not smart enough to post a pic here. Get into the Summit or Jegs web site and type in carb jet extenders, etc. The ones I got came as three pairs, each pair slightly different length. They push over the outside of the jet screw but you may have to warm them a bit with a lamp, etc because they are very tight.
Moroso 65227? http://store.summitracing.com/partdetail.asp?part=MOR%2D65227&view=1&N=700+
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: GO_Fish]
#71763
06/15/08 01:34 AM
06/15/08 01:34 AM
most likely to low (front bowl) and its uncovering the jets. whoever said put jet extentions on the front bowl of any holley is .
