Car stalls under rapid braking #71746
06/11/08 10:53 PM
06/11/08 10:53 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Hello all. My 68 Charger has been stalling when I brake suddenly at lower speeds (i.e., when pulling up to a red light or stop sign). If I slow down gradually everything is fine but if someone slows down in front of me really fast, for example or if I need to slow quickly at lower speeds (not squealing the tires or anything), but hard enough on the brakes, then the car starts to stall. If I don't put it in neutral and pick up the throttle to help it idle, then it begins to stall. I've checked the float levels in the carb and that's all good. Transmission is 904 auto with forward manual pattern. Front brakes have been converted to Mopar disc brakes. Anybody help with this?
Re: Car stalls under rapid braking [Re: 68Bullit] #71747
06/11/08 11:14 PM
06/11/08 11:14 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
do you have a(vacuum) power booster. if so the sudden braking could be stalling the motor, lack of vacuum, being robbed by the booster.
Re: Car stalls under rapid braking [Re: lokalik] #71748
06/11/08 11:26 PM
06/11/08 11:26 PM
Hamtramck, PA
Alaskan_TA Online content
Fluffy Balladeer
Alaskan_TA  Online Content
Fluffy Balladeer
Hamtramck, PA
I had the same problem with a 273 in a '67 Barracuda. The engine seized shortly thereafter.
In my case,the thrust bearing had gone away, when I came to a stop the crankshaft was actually sliding forward inside the engine. The CS counterweight had ground away about 1/4" of the center main web in the block before the engine seized.
Hopefully your problem is not as severe.
Re: Car stalls under rapid braking [Re: lokalik] #71749
06/11/08 11:41 PM
06/11/08 11:41 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Yes I have power brakes. So what's happening with the vacuum? Anything I could do to increase vacuum?
Re: Car stalls under rapid braking [Re: 68Bullit] #71750
06/11/08 11:55 PM
06/11/08 11:55 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
the booster could be making the engine starve down by pulling all or most of the vacuum durning sudden braking. do you know what your manifold vac is? try this disconnect the vac line for the booster, cap the port on your manifold. try the same braking that was causing it to stall, please do this in a safe area. this will answer the question of, is the booster causing this. only way i know of to increas vac is to change the cam. some have suggested a vac canister, i don't know.
Re: Car stalls under rapid braking [Re: 68Bullit] #71751
06/12/08 08:14 AM
06/12/08 08:14 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Are you running a Carter / Edelbrock carb?
Re: Car stalls under rapid braking [Re: Blues_Cuda] #71752
06/12/08 08:58 AM
06/12/08 08:58 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
fuel slosh could uncover the jet.
they sell extension to solve that.
Re: Car stalls under rapid braking [Re: Blues_Cuda] #71753
06/12/08 11:00 AM
06/12/08 11:00 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Holley #4150 650DP
Re: Car stalls under rapid braking [Re: 68Bullit] #71754
06/12/08 11:33 AM
06/12/08 11:33 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
My six packs did the same thing, especially on a downhill slope. I put the plastic tube jet extensions on the center carb and the problem went away.
Re: Car stalls under rapid braking [Re: Classof70Chally] #71755
06/12/08 02:19 PM
06/12/08 02:19 PM
P
Paul_Fancsali Offline
P
A carter carb will do this and the only solution to it is the float height and even then on a hot day it will still do it
Re: Car stalls under rapid braking [Re: 68Bullit] #71756
06/12/08 06:18 PM
06/12/08 06:18 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Holley #4150 650DP
OK. The reason I asked is that the AFB style carbs tend to act like that. Our Max Wedge Savoy does the same thing on the street during aggressive braking and even on the shorter shutdown areas at the mom & pop racetracks.
As mentioned above, try the jet extensions and maybe a vent tube baffle on the Holley.
Re: Car stalls under rapid braking [Re: Blues_Cuda] #71757
06/12/08 06:43 PM
06/12/08 06:43 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Do you have a pic of those things?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Car stalls under rapid braking [Re: 70sixpkrt] #71758
06/12/08 07:09 PM
06/12/08 07:09 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
No, sorry, I'm not smart enough to post a pic here. Get into the Summit or Jegs web site and type in carb jet extenders, etc. The ones I got came as three pairs, each pair slightly different length. They push over the outside of the jet screw but you may have to warm them a bit with a lamp, etc because they are very tight.
Re: Car stalls under rapid braking [Re: Paul_Fancsali] #71759
06/12/08 09:11 PM
06/12/08 09:11 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
my guess was going to be float level too high, flooding the engine. How does it act on restart? Does it light off instantly, or do you have to crank it a little to catch?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Car stalls under rapid braking [Re: GO_Fish] #71760
06/12/08 11:01 PM
06/12/08 11:01 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Most of the time I catch it in time and keep it from stalling but when I rarely miss it and it stalls, it can take a bit of starting before it will hit again. Float levels are good. I have also noticed that going a down a steep hill and while off the throttle that it seems to start running a little rough but the speed/rpm is up enough to keep it from stalling. I'll try the extension, and would it be a good idea to go ahead with a wooden spacer under the carb just for good measure and with the warmer weather?
Re: Car stalls under rapid braking [Re: Classof70Chally] #71761
06/13/08 08:26 AM
06/13/08 08:26 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
Moroso 65227?
http://store.summitracing.com/partdetail.asp?part=MOR%2D65227&view=1&N=700+
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Car stalls under rapid braking [Re: 68Bullit] #71762
06/15/08 12:50 AM
06/15/08 12:50 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Carter and Eddy carbs definitely need a spacer beneath the carb to ease hot starts. Their fuel bowl is integral with the carb body and likes to soak up heat from the intake manifold. Not so much on Holley's since the carb bowls are hanging out in the open air away from direct intake manifold heat. If you have to crank it a bit before it re-fires, it sounds like the engine is flooding/rich.
Re: Car stalls under rapid braking [Re: GO_Fish] #71763
06/15/08 01:34 AM
06/15/08 01:34 AM
most likely to low (front bowl) and its uncovering the jets. whoever said put jet extentions on the front bowl
of any holley is .
Re: Car stalls under rapid braking #71764
06/15/08 01:51 AM
06/15/08 01:51 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
of any holley is .
Holley says they might be needed if it happens under hard acceleration where the fuel is pulled away from the jets...why is it crazy to have to put them up front if it happens under hard braking?
although, my Holley 4150 (750HP) does not have them and I don't have any problems.
maybe I don't have enough power to accelerate fast enough, or enough brakes to stop hard enough that I need the extensions?
**Photobucket sucks**
Re: Car stalls under rapid braking [Re: 70Cuda383] #71765
06/15/08 12:20 PM
06/15/08 12:20 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
On a six pack the only time the jets can become uncovered is under hard braking, especially going down hill (for those of us who have hills). No one can tell me it doesn't happen because after putting jet extenders on my center carb the problem "magically" disappeared.
