Evac nipple location #717568
06/06/10 12:54 PM
06/06/10 12:54 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
How far from the end of the header do you weld the nipple for a evac setup
Re: Evac nipple location [Re: flatiron] #717569
06/06/10 06:08 PM
06/06/10 06:08 PM
Az
Crizila Offline
Crizila  Offline
Az
Most want it located right after the 4 in to 1 junction area.
Fastest 300
Re: Evac nipple location [Re: flatiron] #717570
06/06/10 06:43 PM
06/06/10 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put the end of the nipple about 3" past the end of the
primary tubes IF you dont run a O2 sensor.... O2 sensor
should be UP stream of the evac
Re: Evac nipple location [Re: MR_P_BODY] #717571
06/06/10 07:38 PM
06/06/10 07:38 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Ok headers are already on car and welding the nipple in on top of collector will be a job. Would it matter if I welded them on the side say at 3 and 9 oclock postions
Re: Evac nipple location [Re: flatiron] #717572
06/06/10 07:45 PM
06/06/10 07:45 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
It won`t matter.............
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Evac nipple location [Re: flatiron] #717573
06/06/10 07:51 PM
06/06/10 07:51 PM
Az
Crizila Offline
Crizila  Offline
Az
Don't know that it makes a difference circumference wise. The Moroso instructions show them mounted in the crevice ( and there are 4 to choose from )of the collector just aft of the 4 in to 1 junction at 45 degree angle. Assume they consider that a low pressure area on most headers.
Fastest 300
Re: Evac nipple location [Re: flatiron] #717574
06/06/10 08:22 PM
06/06/10 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Where did you get the idea of 12 o clock the sides are
fine
Re: Evac nipple location [Re: MR_P_BODY] #717575
06/07/10 12:01 AM
06/07/10 12:01 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
fine
Seems like most of the ones I seen the nipple was on top
Re: Evac nipple location [Re: flatiron] #717576
06/07/10 01:50 AM
06/07/10 01:50 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
If you are going to try inside , make real sure that the transmission won't interfere too.
Don't ask me how I know that one.
Mocking up outside the car ain't all it's cracked up to be.
Re: Evac nipple location [Re: flatiron] #717577
06/07/10 07:34 AM
06/07/10 07:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
fine
I have never seen them on top... too hard to get to
