Installation advise needed for a Conv Top #717539
06/06/10 12:02 PM
06/06/10 12:02 PM
PA - Phila
71GRANCOUPE Offline OP
PA - Phila
I am looking at installing a new convertible top on my 68 barracuda. I have never done this before.
Should I have a professional do it or is this something I could tackle myself with a little help?
Any suggestions from those who have done their own would be appreciated.
68 Barracuda Conv
Re: Installation advise needed for a Conv Top [Re: 71GRANCOUPE] #717540
06/06/10 01:51 PM
06/06/10 01:51 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This may shed a little light on the task. Myself, I would get the top from ledgendary and spring for the glass back window. I believe Dante's can save you some money.
http://www.moparmusclemagazine.com/techa...tion/index.html
Re: Installation advise needed for a Conv Top [Re: 71GRANCOUPE] #717541
06/06/10 01:58 PM
06/06/10 01:58 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Installation advise needed for a Conv Top [Re: 71GRANCOUPE] #717542
06/06/10 04:22 PM
06/06/10 04:22 PM
IMGTX Offline
IMGTX  Offline
I installed my own and it took me a couple days but I only worked on it after school.
After removing the old top I laid the new one on the frame to unwrinkle it.
I inserted the tension wires.
I aligned and stapled the top to the main rear frame hoop. I didn't use many staples in case I had to reposition it.
Note: When you install the fold over seam cover on the rear top loop make sure it folds over backwards so air won't unfold it when you drive.
I stretched the roof over the side window area and loosely attached the weatherstrip retainers along the side.
I loosely bolted the rear top retainer to the body with the top under it.
Focusing mainly on the rear half I proceeded to stretch and adjust the top to get the wrinkles out.
Once I got the top where I wanted I marked the top and retainer rails in relation to the top.
I removed the retainer rails and tacked the top to the retainer rails making sure the marks lined up.
I adjusted the top tension at the front windshield retainer so the top would stretch when lowered but not prevent the top from closing.
Lastly I continued to stretch the top and install the weather strip retainers along the sides.
Once I was comfortable I added the rest of the tacks where lacking, rechecked the fit and then trimmed the edges.
Hope it helps.
Re: Installation advise needed for a Conv Top [Re: IMGTX] #717543
06/06/10 04:53 PM
06/06/10 04:53 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
do it yourself. I do all of my own after having a so called pro get the backlight 3 inches off center and would not correst it. Cost me 350 doolars for that lesson (early 80's) at what it cost to have one done now you can ruin a few and be cash ahead.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
