Page 1 of 3 1 2 3
Junk motor mounts..UPDATE AGAIN #717400
06/06/10 09:29 AM
06/06/10 09:29 AM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Can't believe my motor mounts have broken already.. Stock 440 in my 67 with 1500 miles on the engine and mounts.. One very small burnout and mostly just some crusing done with these..
Bought the mounts from NAPA and when I saw made in India I was worried, but I thought they would last a while...
Any update on some recommendations and sources here for some new good ones???
Re: Junk motor mounts [Re: minivan] #717401
06/06/10 10:34 AM
06/06/10 10:34 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I went through this on my old slant 6. The original rubber mounts lasted 35 years and the replacements lasted a year!
I ended up going with poly drivers side and stock passenger mounts. The crap mount lasted way better in compression than being pulled apart by engine torque.
On my 408 I used Schumacher mounts. Way more money but the quality is there.
Good luck
Re: Junk motor mounts [Re: minivan] #717402
06/07/10 01:36 AM
06/07/10 01:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You might have to step up to the interlocking poly mounts offered by Schumacher. NOT cheap, but install it ONCE and be done with it.
Re: Junk motor mounts [Re: Kern Dog] #717403
06/07/10 06:50 AM
06/07/10 06:50 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Yeah, but the poly are reputedly harsh? How about the mitymounts (rubber with steel interlock)
Re: Junk motor mounts [Re: Gavin] #717404
06/07/10 10:03 AM
06/07/10 10:03 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The India made mounts are JUNK. It doesn't matter what name is on the box. You can tell by the look and feel of the rubber (well, I'm not even sure it's really rubber, might be elephant fat for all I know). I did buy a pair of mounts from Kragen (O'Reilly) a few weeks ago for the Ramcharger. They were made in Korea, which appear to better made and with better material. They also have a lifetime warranty.
I also recently made a transmision mount for my wife's 95 LeBaron. The only mounts available were a junk mount from the local transmission parts house for about $35 or the dealer for about $200. A poly sway bar bushing and some square tubing, DONE. I do feel some extra vibration at idle from time to time, but the acceleration shake is gone.
Re: Junk motor mounts [Re: Jim_Lusk] #717405
06/07/10 11:31 AM
06/07/10 11:31 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Do the cars use the same rubber mount as trucks? If so get Diesel mounts
Re: Junk motor mounts [Re: 76dodgeboy] #717406
06/07/10 04:46 PM
06/07/10 04:46 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
thanks for the replys..
Any dealers for Shumacher mounts or the polys?? I like the Shumachers but not sure I need all that.. I do like the idea of doing this only once ( again)
Any other suggestions out there??
Re: Junk motor mounts [Re: 76dodgeboy] #717407
06/07/10 04:47 PM
06/07/10 04:47 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope, completely different and even different than earlier K-car derivatives.
Re: Junk motor mounts [Re: minivan] #717408
06/07/10 07:13 PM
06/07/10 07:13 PM
IN
ahy Offline
ahy  Offline
IN
Schumacher sells directly and through Mancini and others. I have the older version Schumacher mount - rubber with through bolt - on a 496B and it has been trouble free. I would buy the interlocking type if I were in the market now. Usually only one is required (drivers) with a good quality standard mount on the other. This helps limit vibration. If you call schumacher they'll get you fixed up.
The other fix is a chain or a strap from the block to the frame to control engine twist. I don't run one but if you ask you'll get lots of pics of different setups.
Re: Junk motor mounts [Re: ahy] #717409
06/07/10 10:26 PM
06/07/10 10:26 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I had the local parts store order 4 of them, one was made in Korea and has held up to some abuse..
The India mount didnt last one day...
part number 2250..
Re: Junk motor mounts [Re: sthemi] #717410
06/09/10 04:19 PM
06/09/10 04:19 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
I ordered the Schumachers today.. I didn't want to do this job again..
Hope they come with some grease.....
Re: Junk motor mounts [Re: minivan] #717411
06/10/10 11:47 PM
06/10/10 11:47 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Well funny thing is the drivers side india motor mount is out and it is OK????
Any chance these cheap ones can really move around?? The drivers side was coming up what looked like 2-3 inches when I power braked the car.... Should I be looking for something else wrong??
Gonna install the Schumachers and see how it does.....
Re: Junk motor mounts [Re: minivan] #717412
06/11/10 12:45 AM
06/11/10 12:45 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Oh yeah, they can move around.
Re: Junk motor mounts..UPDATE [Re: minivan] #717413
06/11/10 01:25 AM
06/11/10 01:25 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Is it possible that they soften to a gooey "chewing gum" consistency when they get warm from engine heat?
Re: Junk motor mounts..UPDATE [Re: minivan] #717414
06/11/10 07:22 AM
06/11/10 07:22 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Add a chain and be done with it.
Re: Junk motor mounts..UPDATE [Re: Kern Dog] #717415
06/11/10 08:25 AM
06/11/10 08:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is it possible that they soften to a gooey "chewing gum" consistency when they get warm from engine heat? [/quote
No , they soften because of the INFERIOR rubber they are made of .
Re: Junk motor mounts..UPDATE [Re: ireland383] #717416
06/11/10 12:17 PM
06/11/10 12:17 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
This and you can get a nice torque strap from Schemaker as well if you want.
Re: Junk motor mounts..UPDATE [Re: SomeCarGuy] #717417
06/11/10 12:32 PM
06/11/10 12:32 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
I have the Schumachers on my 340, and they're great. I have no more worries about breaking a mount and losing my fan shroud.
Re: Junk motor mounts..UPDATE [Re: SomeCarGuy] #717418
06/11/10 01:11 PM
06/11/10 01:11 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Yup, a chain or a sliding mount like the carb kickdown linkage, Gives play at idle but then halts any movement past a point. That is what is needed. My 65 A mounts are 3 inches tall of rubber..I will be using a "motor torsion limiting device". Interlocking mounts are acceptable.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Junk motor mounts..UPDATE [Re: pishta] #717419
06/11/10 05:08 PM
06/11/10 05:08 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Thanks for the replies..
I am aware of torque straps etc..
What I am saying is I have seen busted motor mounts before and based on the amount of lift from the drivers side of the motor while lightly powerbraking my car, it sure looked like one to me and I was very surprised to see both of my " made in india" mounts were not broken...
I will update this post after I start it with the new Schumacher mounts in and let everyone know what the difference is.....
Page 1 of 3 1 2 3
