locking mopar dist. #717297
06/06/10 01:16 AM
06/06/10 01:16 AM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
anyone know how to lock timing on mopar billet dist?weld?
Re: locking mopar dist. [Re: top8x7b] #717298
06/06/10 01:21 AM
06/06/10 01:21 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
why would you lock timing at 4 Deg or so ?
Dan
Re: locking mopar dist. [Re: Wedgeman] #717299
06/06/10 10:52 AM
06/06/10 10:52 AM
s.e. michigan
top8x7b Offline OP
top8x7b  Offline OP
s.e. michigan
4 degrees? what? want to eliminate centrifical advance ,so timing stays at set degrees example 36 all the time
