3 inch exhaust with 2.5 inch tailpipes #717205
06/05/10 09:29 PM
06/05/10 09:29 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Has anyone done 3 inch from the manifolds into 2.5 inch tailpipes? This is on a 440 stroked to 493. I asked one of the guys as Mancini if they could sell me a TTI setup like this and he thought I was crazy. Any thoughts appreciated.
Thanks,
Steve
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: srunge55] #717206
06/05/10 09:42 PM
06/05/10 09:42 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Actually, I talked to Rick Ehrenberg about a year ago about exhaust systems and he recommended 3" head pipes and mufflers off my TTi headers, and 2.5" pipe from there back - and that was on a 364ci SB.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: srunge55] #717207
06/05/10 09:44 PM
06/05/10 09:44 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
the question here is why would you want to drop size to 2.5 if they have a 3 " kit i vote for using it all the way ????
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: calrobb2000] #717208
06/05/10 11:36 PM
06/05/10 11:36 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Main reason for the 2.5 tailpipes is I thought 3 inch would be tight and I have a set of 2.5 inch exhaust tips I'd like to use. I guess I could cut them up to work but didn't really want to. I thought I had read about guys doing this alot.
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: srunge55] #717209
06/06/10 12:05 AM
06/06/10 12:05 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
You'll be fine with 2.5" tailpipes. Power loss is minimal due to the exhaust gases being cooler after the mufflers.
There was an exhaust test done many years ago on a BB race car and it showed only a very, very small difference on the dyno and ET at the track.
Plus the car won't be as loud with 2.5" tailpipes.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: srunge55] #717210
06/06/10 12:05 AM
06/06/10 12:05 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If you can get mufflers with a 3" inlet and a 2.5" outlet you'll be fine. Order the pieces you want from TTI.
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: bobby66] #717211
06/06/10 10:07 AM
06/06/10 10:07 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
I haven't checked around much lately but the deal with the mufflers awhile back was that any muffler advertised as 3"/2.5" had the inlet choke back down to 2.5" inside the case which essentially made it a 2.5" anyway.
Basically they were 2.5/2.5 mufflers expanded out to 3" inlet.
Probably better off getting 3"/3" muffler and adapting the tailpipe down to 2.5".
That being said it was easier just to order a TTI 3" system.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: BrianShaughnessy] #717212
06/06/10 10:34 AM
06/06/10 10:34 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I had a local shop make my 3" h-pipe from my headers to mufflers and just bought the tti 2.5" tailpipes and had him use those. I do have just 2.5" mufflers though. Not ideal, but it works for me.
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: Jeff_383] #717213
06/06/10 10:46 AM
06/06/10 10:46 AM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
1969 charger 383 headers 3 inch h pipe 2.5 inch tailpipe flow master mufflers , brand new engine .way to loud for me, maybe getting old but then again i run 12,000 horse power diesels 6 days a week and have the proof that ive lost hearing still too loud ..puting on hush thrush
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 3 inch exhaust with 2.5 inch tailpipes [Re: sparcy] #717214
06/06/10 10:55 AM
06/06/10 10:55 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have Dynomax superturbos. Very mellow, I can listen to the radio and talk to people in the car.
