need to get the distributor turned backwards more? #716902
06/05/10 05:22 PM
06/05/10 05:22 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
my intake is hitting my msd pro billet distributor, and i need to retard it a tad more in order to phase in the distributor, which way do i go with the distributor gear drive to get more movement with the distributor going backwards? thanks
Re: need to get the distributor turned backwards more? [Re: JACKSON] #716903
06/05/10 05:47 PM
06/05/10 05:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look down the hole and see where its at... then use
a big screw driver... it'll only turn one way to come
out of the cam gear... just think in your head which
way you want to go... you might have to go 2 teeth
short of 1/2 way around
Post deleted by Defbob [Re: MR_P_BODY] #716904
06/05/10 06:05 PM
06/05/10 06:05 PM
Re: need to get the distributor turned backwards more? #716905
06/05/10 06:12 PM
06/05/10 06:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
or you can just move the wires over once its in the best place
Or do like Fred said
Re: need to get the distributor turned backwards more? [Re: MR_P_BODY] #716906
06/05/10 06:12 PM
06/05/10 06:12 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
When you turn it out, like Mike suggests, you can start skipping teeth until you get it in the position you want. The firing order won't change, just the position of the intermediate shaft to the cam gear.
Re: need to get the distributor turned backwards more? [Re: Leigh] #716907
06/05/10 06:52 PM
06/05/10 06:52 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
which way to turn the gear a few turns clockwise or counterclockwise in order to get the distributor to turn backwards or retarded more. im out of room at the intake?
Re: need to get the distributor turned backwards more? [Re: JACKSON] #716908
06/05/10 07:27 PM
06/05/10 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you move the shaft you want to go in the direction
that you want to move the dist... if you move the
plug wires you go in the opposite dicrection, that
way you have to turn the dist back to get the timing
cant tell you which way to go because you didnt say
what engine... they turn opposite directions
Re: need to get the distributor turned backwards more? [Re: MR_P_BODY] #716909
06/05/10 08:08 PM
06/05/10 08:08 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
thanks mr.p
it's a hemi,of course.
Re: need to get the distributor turned backwards more? [Re: JACKSON] #716910
06/05/10 09:46 PM
06/05/10 09:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
Bring the motor up to TDC on #1, make the slot in the oil pump drive align with the cam and crankshaft. Asssemble and check the ignition timing, should be good to go Let us know your results
Post deleted by Defbob [Re: Cab_Burge] #716911
06/05/10 10:12 PM
06/05/10 10:12 PM
Re: need to get the distributor turned backwards more? #716912
06/06/10 12:45 AM
06/06/10 12:45 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
We set all of our wiresets with #1 being at 5 O'Clock. Like the factory. But if you set #1 at 7 o'clock, 3,5, and 7 are easily pointed to their side of the engine.. For what it's worth, our Mechanical Distributor has a much-smaller head. It's easier and has more room to spin for adjusting.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
