Front Spring hanger 73 Charger #716860
06/05/10 04:01 PM
06/05/10 04:01 PM
Baltimore, MD
3
397STROKER Offline OP
super street
super street
3
Baltimore, MD
I pulled the rear and springs from my 73 charger and was cleaning up the front hangers when I noticed that they are not the same. One is shorter than the other an when I measure the distance from the mounting surface to the center of the bolt hole, one is 2 3/4" the other is 2 1/4". Is this by design and there is a right and left hanger or did someone before me replace one with the wrong on?
Re: Front Spring hanger 73 Charger [Re: 397STROKER] #716861
06/05/10 10:54 PM
06/05/10 10:54 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Sounds like one incorrect hanger.
Re: Front Spring hanger 73 Charger [Re: Magnum] #716862
06/05/10 11:11 PM
06/05/10 11:11 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Is one spring eye round and the other oval?
Re: Front Spring hanger 73 Charger [Re: Mr_fixit] #716863
06/06/10 09:34 AM
06/06/10 09:34 AM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
Both spring eyes are round. Could one be off an earlier B body? I would think if it was from an A-body there would be like a 2" difference not just a 1/2". Could the 1/2" just be one of those early QC issues, you know, close enough.
Re: Front Spring hanger 73 Charger [Re: 397STROKER] #716864
06/06/10 11:00 AM
06/06/10 11:00 AM
BDW Offline
BDW  Offline
Any way you could post a couple of pics? Might be tolerance? Both sides off 1/4" adds up to 1/2"
Re: Front Spring hanger 73 Charger [Re: BDW] #716865
06/06/10 07:45 PM
06/06/10 07:45 PM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
Here is a picture with the brackets sitting next to each other. One is taller.
Re: Front Spring hanger 73 Charger [Re: 397STROKER] #716866
06/06/10 07:46 PM
06/06/10 07:46 PM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
Here is on of the holes next to each other. You can see the difference in the alignment of the holes.
Re: Front Spring hanger 73 Charger [Re: 397STROKER] #716867
06/06/10 10:22 PM
06/06/10 10:22 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I've got a 73 Charger 8 3/4 with the springs still attached, sitting in the garage....I'll go check a few measurements. Be back in a few.
Re: Front Spring hanger 73 Charger [Re: 440trk] #716868
06/06/10 10:24 PM
06/06/10 10:24 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Proper distance from the mounting surface to the Centerline of the leaf spring bolt is 2 1/4" on both sides.
Re: Front Spring hanger 73 Charger [Re: 440trk] #716869
06/07/10 10:48 AM
06/07/10 10:48 AM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
Thanks 440trk. I wonder why one would be 2 3/4" and if that is correct for another year or body style.
Re: Front Spring hanger 73 Charger [Re: 397STROKER] #716870
06/08/10 02:21 AM
06/08/10 02:21 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I'll measure my 71s spring hanger this weekend, if you don't get a response before then.
Glad to help out.
