msd crank trigger pickup clearance to wheel #716803
06/05/10 02:48 PM
06/05/10 02:48 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
whats the correct distance to the pickup to wheel on msd crank trigger for bb. i think its .060, can't remember .
Re: msd crank trigger pickup clearance to wheel [Re: JACKSON] #716804
06/05/10 02:53 PM
06/05/10 02:53 PM
NC
440Jim Offline
440Jim  Offline
NC
Re: msd crank trigger pickup clearance to wheel [Re: 440Jim] #716805
06/05/10 04:36 PM
06/05/10 04:36 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
I have mine set at 0.060".
The instructions are on the MSD web site. http://www.msdignition.com/uploadedfiles...nstructions.pdf
And this one:
http://www.msdignition.com/instructions/Products/fmct_wiring_frm28731.pdf?terms=Crank+Trigger
THANKS JIM, i looked on the website but couldn't find it.
so i need to get the distributor turned backwards a little more.my intake is in the way so i can phase the distributor in, which way to turn the distributor gear drive in order to get the distributor in the right place so i can turn it more.
