OK, THE TRUCK ARRIVES!!!!!!!!
Original Mopar Tuff steering wheel + addapter "Hard pice to come by, and not cheap"
Good used front lower balance, bumper guards deleted
Manual aluminum steering box "real light unit"
Mancini Racing billet front motor plate, fluid damper harmonic ballancer, hurst competition shifter, custom disc brake front conversion i pice together with wilwood parts and RX-7 rotors
Eagle rods with arp2000 bolts for the 440 big block engine "check em up in comparation with the 2jz rod!
4 speed new procces mopar crash box! "SWEETTT"
Eddy Torker 440 intake and B1 big block valve covers
440 Source SFI billet flywheel
440 Source billet 1/4 inch gridle and main studs assembly with windage tray and billet rear main seal cap
1968 HP2 mopar big block 440 engine and Lakewood scattershield
3.73 gears Dana 60 diff
Stick [Edited by Moparts - Family Friendly Site - Keep it clean] pedal assembly
Car Tool 1/8 inch contoured subframe connectors specially build for the Dart
