Guys running E-85 #716187
06/04/10 05:57 PM
06/04/10 05:57 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
Just curious as what is the largest jets you have run. I just converted a 1050 and 99 were not large enough and gas only goes up to 110 they then jump to 127
Re: Guys running E-85 [Re: dbran451] #716188
06/04/10 06:41 PM
06/04/10 06:41 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
147 drill size alky jets in all 8 corners on 2 1250 doms.
Re: Guys running E-85 [Re: dbran451] #716189
06/04/10 10:42 PM
06/04/10 10:42 PM
NC
440Jim Offline
440Jim  Offline
NC
You might want to consider an airbleed change rather than larger main jets. Did you increase the booster flow size when you converted the carb? Did you change the metering blocks? Is it a 2 or 3 circuit Dominator?
Re: Guys running E-85 [Re: 440Jim] #716190
06/05/10 07:06 AM
06/05/10 07:06 AM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
This is a Quick Fuel kit so its yes to the booster,metering block needle and seat it was set up to there specs with #28 air bleeds we started with 97 jets then went to 99. I spoke to Quick fuel and they said jet up before changing air bleeds and I was wondering how large guys have run. I was gaining more temp than I should be so I am going to 103 and go up as needed.
8896 three circuit
Re: Guys running E-85 [Re: dbran451] #716191
06/05/10 09:35 AM
06/05/10 09:35 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I have a 1050 dominator 3 circuit that was converted to E85. LM1 showed lean going down track.We started with 98 in the front and 106 in the back.Now we are at 101 and 111s in the back. The car really picked up from the 330 on and ran the best numbers it has ever ran in the cool weather and this day the temp was 88 degrees and terrible air.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Guys running E-85 [Re: dbran451] #716192
06/05/10 10:56 AM
06/05/10 10:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Right now I have 96s in my 8896... I forget the air
bleed size... but QF set it up for me and worked almost
perfect... I did jet up 2 jet sizes from their spec
Re: Guys running E-85 [Re: MR_P_BODY] #716193
06/05/10 02:17 PM
06/05/10 02:17 PM
NY
challenger451ci Offline
NY
Depending on conditions, I use 96's to 100's square in my 8896 with a Quick Fuel conversion kit. HS bleeds are around 0.016" if I remember correctly.
Re: Guys running E-85 [Re: slippery440] #716194
06/05/10 02:28 PM
06/05/10 02:28 PM
NC
440Jim Offline
440Jim  Offline
NC
What were the A/F or Lambda readings before and after your jet change?
Re: Guys running E-85 [Re: 440Jim] #716195
06/05/10 02:56 PM
06/05/10 02:56 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
9 to 10 lambda and now in the eights.Still could go a bit more.I may play with the HS air bleed.
Re: Guys running E-85 [Re: slippery440] #716196
06/05/10 03:07 PM
06/05/10 03:07 PM
NC
440Jim Offline
440Jim  Offline
NC
I assume you mean Lambda of 0.90-1.0 before, and 0.8x after?
Re: Guys running E-85 [Re: slippery440] #716197
06/05/10 05:16 PM
06/05/10 05:16 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
Do you have power valves just seems like a big spread
Re: Guys running E-85 [Re: 440Jim] #716198
06/05/10 07:15 PM
06/05/10 07:15 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Yep thats what I should of wrote.The guy that did the carb likes to use a power valve as anouther circuit for fuel.When the carb was 110 gas the jets were 96 square with no power valve.
