grounding problem with top of fender turn lights #716126
06/04/10 04:21 PM
06/04/10 04:21 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
i cant seem to get a good ground on them, tried everything, thinking of solding a wire to the bulb housing and making a ground.
anybody else have this problem
Re: grounding problem with top of fender turn lights [Re: AK_JH27] #716127
06/04/10 05:27 PM
06/04/10 05:27 PM
Under My Car
Mopar_Country Offline
Under My Car
I have them on my Dart Sport with no problems. It may be the light socket itself.
Re: grounding problem with top of fender turn lights [Re: Mopar_Country] #716128
06/05/10 12:53 AM
06/05/10 12:53 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i had the same problem! got one of the tiny little star washers with the serrations.. put them between fender and light... work perfectly now..may take a little fiddling..good luck dan
