Broken wire on clutch safety switch - how to fix? #716030
06/04/10 01:36 PM
06/04/10 01:36 PM
KS
MoparKansas Offline OP
KS
The wire broke on my clutch safety switch on my 73 Challenger. How would yo go about fixing this? I took it apart and the wire goes into a brass tab that is riveted in. No room to solder at all. I actually have two that are this way.
Any suggestions on how to fix it?
Re: Broken wire on clutch safety switch - how to fix? [Re: MoparKansas] #716031
06/04/10 01:52 PM
06/04/10 01:52 PM
P
Paul_Fancsali Offline
P
Ground the connection on the relay and call it a day. I would not waste my time fixing it. Don't want to do that get a stick starter relay from a 1969 or 68 model and use it. and store the connection
