1970 440 cam question. #716004
06/04/10 12:25 PM
06/04/10 12:25 PM
Loveland CO
Jimbo Offline OP
Jimbo  Offline OP
Loveland CO
i have a stock, low mile 440 that I want to run in my car, and was curious on how much cam I can run safely. I was specifically looking at the .528 purple shaft, but with the flat pistons, i didn't know if it will smack the pistons or not.
Re: 1970 440 cam question. [Re: Jimbo] #716005
06/04/10 12:42 PM
06/04/10 12:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'll be fine. Once you adjust the lash out the cam specs are around 500-504 lift depending on how tight you set it. I set mine tight at .020/.022. You will need adjustable rockers though.
Coming soon!!!!
Re: 1970 440 cam question. [Re: Mr.Yuck] #716006
06/04/10 02:02 PM
06/04/10 02:02 PM
Loveland CO
Jimbo Offline OP
Jimbo  Offline OP
Loveland CO
i was wondering about lash, the lash spec seemed excessive to me. how does the cam behave? I had it in a 360 years ago and liked it.
Re: 1970 440 cam question. [Re: Jimbo] #716007
06/04/10 02:33 PM
06/04/10 02:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
worked great on my stockish 440-6 until I spun #4.
