360 Distributor collar to remove timing jump #715702
06/03/10 11:54 PM
06/03/10 11:54 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
Somewhere I read that you can get a collar to put on the distributor shaft to make the timing more stable. Anyone have pictures or any info?
Post deleted by moparts [Re: moparmikethree] #715703
06/04/10 08:59 AM
06/04/10 08:59 AM
Post deleted by moparts #715704
06/04/10 08:59 AM
06/04/10 08:59 AM
Re: 360 Distributor collar to remove timing jump #715705
06/04/10 09:23 AM
06/04/10 09:23 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I believe he is talking about a additional collar the goes on the lower part of the shaft to reduce timing jump. It is held in place by some set screws.
http://www.hughesengines.com/Index/produ...mp;partid=25200
Re: 360 Distributor collar to remove timing jump [Re: mopars4ever] #715706
06/04/10 10:04 AM
06/04/10 10:04 AM
Andrewh Offline
Andrewh  Offline
how does that work?
or rather what is it preventing from moving?
Re: 360 Distributor collar to remove timing jump [Re: moparmikethree] #715707
06/04/10 11:06 AM
06/04/10 11:06 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This is what you want.
http://s542.photobucket.com/albums/gg408...pg&newest=1
at Hughes
When the drive gear bounces up and down it turn a bit moving the timing back and forth this collar really works.
I made mine some get 1/2 motor shaft collars at TSC (tractor supply)
I used a 1/2 locking nut drilled out and tapped for a set screw. But dam it really works
http://s542.photobucket.com/albums/gg408...pg%26newest%3D1
Re: 360 Distributor collar to remove timing jump [Re: Dodgem] #715708
06/04/10 11:16 AM
06/04/10 11:16 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
What will do the most to achieve your timing jump elimination is a timing chain tensioner kit.
Re: 360 Distributor collar to remove timing jump [Re: Andrewh] #715709
06/04/10 11:45 AM
06/04/10 11:45 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
When there is room for the oil bump/distributor drive gear to move up and down it naturally turns.
Like when your turning the gear in and out with a screw driver! and when it turns it affects the timing fore and back.
so the collar holds the drive gear down into place so it stablises the timing a lot. I have a milidon gear drive and still had a problem. the collar eliminated the problem completely!!
Re: 360 Distributor collar to remove timing jump [Re: Dodgem] #715710
06/04/10 12:41 PM
06/04/10 12:41 PM
Try this
close the gap on your electronic distributor some--it makes that jump go away most of the time
Re: 360 Distributor collar to remove timing jump [Re: Dodgem] #715711
06/04/10 01:39 PM
06/04/10 01:39 PM
Andrewh Offline
Andrewh  Offline
interesting. Thanks for the explination.
Re: 360 Distributor collar to remove timing jump [Re: Andrewh] #715712
06/04/10 04:36 PM
06/04/10 04:36 PM
(1) close the reluctor gap to .006" at the tightest point as different reluctor vanes stick out farther and the vac adv will pivot and change the gap also (got a Mityvac) (2) get the collar and slide it on & snug it w the setscrew and install the dist all the way tightened to the block w the clamp then carefully remove the dist and fully tighten up the collar in it's located position. (3)Get the aforementioned timing tensioner and a GOOD QUALITY tchain set. EDIT also 1st remove the oe roll pin/collar that's in the oe location in Drjayo's pic and add shims to reduce the shaft end play to near zero & reinstall it. The added one is seperate and goes on the end just above the tang
