Post deleted by moparts
[Re: moparmikethree]
#715703
06/04/10 08:59 AM
06/04/10 08:59 AM
#715704
06/04/10 08:59 AM
06/04/10 08:59 AM
Re: 360 Distributor collar to remove timing jump
[Re: Dodgem]
#715710
06/04/10 12:41 PM
06/04/10 12:41 PM
Try this close the gap on your electronic distributor some--it makes that jump go away most of the time
[Re: Andrewh]
#715712
06/04/10 04:36 PM
06/04/10 04:36 PM
RapidRobert
(1) close the reluctor gap to .006" at the tightest point as different reluctor vanes stick out farther and the vac adv will pivot and change the gap also (got a Mityvac) (2) get the collar and slide it on & snug it w the setscrew and install the dist all the way tightened to the block w the clamp then carefully remove the dist and fully tighten up the collar in it's located position. (3)Get the aforementioned timing tensioner and a GOOD QUALITY tchain set. EDIT also 1st remove the oe roll pin/collar that's in the oe location in Drjayo's pic and add shims to reduce the shaft end play to near zero & reinstall it. The added one is seperate and goes on the end just above the tang
