Re: Power Windows - Power Connection / Source?
[Re: Dodge Don]
#715555
06/03/10 11:04 PM
06/03/10 11:04 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If it is afermarket and not full factory, I would get them their own power source from the starting relay, (less strain on the system) just make sure to use a fuse and a relay with a signal from the radio or some other 'on' with ignition source. This way the windows only work when the ignition is on.
This still puts the power take off on the other side of the ammeter.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#715557
06/04/10 01:07 AM
06/04/10 01:07 AM
Posts: 7,759 So Cal
HealthServices
So Cal
And I would wire it all under the dash to keep it clean...
Allen
[Re: 440challenger]
#715560
06/04/10 08:53 AM
06/04/10 08:53 AM
Posts: 518 COLLINGWOOD, ONT
71_deputy
COLLINGWOOD, ONT
Don-the radio power only is to turn on the safety relay- that relay then provides power- via heavier wiring and 30 amp circuit breaker for protection
checkout the attached wiring diagram and follow it. a after market relay-Bosch_ will work for this!!
