Shifting issue w/ 69 Charger #714719
06/02/10 11:46 PM
06/02/10 11:46 PM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
I have a 383 w/ 727 trans. trans is rebuilt, but sat for a while. Shifts into gear good, but I have a problem. I tried to test drive today. wont shift out of 1st...What might it be? It has a new cable kick down.
Re: Shifting issue w/ 69 Charger [Re: lukendan] #714720
06/03/10 01:25 AM
06/03/10 01:25 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
Ideas???? Need help. Might it be band adjustments?
Re: Shifting issue w/ 69 Charger [Re: lukendan] #714721
06/03/10 01:38 AM
06/03/10 01:38 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
I have only drove it 2 trips that were only 1/2 block each way. It was revving high and holding its gear. My buddy just told me to go put a mile on it, then see???
Re: Shifting issue w/ 69 Charger [Re: lukendan] #714722
06/03/10 01:43 AM
06/03/10 01:43 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had this problem with a 727 in my Charger years ago. I had a 727 rebuilt to swap in, then some time passed. 18 months later I swapped headers and installed the "rebuilt" trans, along with a 3000 stall converter. It seemed okay at first, but within a couple of miles the trans seemed to slip alot. At one point while in park, I couldnt rev it past 2800-3000 rpms and it felt like it was both in gear and in park at the same time. When I smelled the fluid, it was almost black and really stunk.
The shop covered the trans. Sure, I had to swap it out, but no BFD. Later when they tore the trans down, the man said that the clutched were welded to the case and grit was everywhere inside. The trans was scrap. NOT trying to scare you, but I have wondered for awhile if the trans was AFU from the start or did it cause damage sitting through the summer and winter....Hmmmmm.
Re: Shifting issue w/ 69 Charger [Re: lukendan] #714723
06/03/10 03:26 AM
06/03/10 03:26 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Most likely your problem. Your cable is not adjusted right.
Re: Shifting issue w/ 69 Charger [Re: Hotwheelsjr] #714724
06/03/10 03:59 AM
06/03/10 03:59 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
...roger that. BE SURE that the KD lever moves the full range. It is probably locked FULLY to the rear.
Re: Shifting issue w/ 69 Charger [Re: lukendan] #714725
06/03/10 07:11 AM
06/03/10 07:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll echo the rest..adjust your cable, better yet get rid of it and get the right linkage.
Coming soon!!!!
Re: Shifting issue w/ 69 Charger [Re: Mr.Yuck] #714726
06/03/10 02:10 PM
06/03/10 02:10 PM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
Found out that it has a reverse valve body. The tranny was rebuilt by a local mopar performance shop. It was a left over they had. I guess they forgot to fill me in. Should I leave it in or change it? And does that mean my kick down is not usefull now?
Re: Shifting issue w/ 69 Charger [Re: lukendan] #714727
06/03/10 02:19 PM
06/03/10 02:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd leave it in. You'll just have to shift it manually. and No you shouldn't need the kickdown. But ask the trans shop.
Coming soon!!!!
