Re: oil leaking from head gasket
[Re: moparbud]
#714606
06/02/10 10:49 PM
06/02/10 10:49 PM
Thumperdart
State of confusion
Are you POSITIVE it`s not the valve cover gasket? My eyes caught the same thing on my dart and that`s what it turned out to be. If not, what type of gaskets and compression for starters......
[Re: Thumperdart]
#714608
06/02/10 10:56 PM
06/02/10 10:56 PM
Posts: 7,664 IN
ahy
IN
Agree. I tried the "really good and thick" valve cover gaskets and they leak. Next time its standard cork/rubber for me. They seep a little but don't leak.
[Re: moparbud]
#714611
06/03/10 12:15 PM
06/03/10 12:15 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
Look really closely for the source of the oil, I bet that it is coming from the intake valley cover and then following the head gasket to where it looks like it is leaking from Unless this is a street hemi motor I have seen the head gaskets on a street hemi motor leak oil at the oil return passages on the outside corners due to a rough deck surface using Cometic head gaskets
