Re: air bleeds
[Re: EDDIEB]
#714568
06/03/10 12:24 PM
06/03/10 12:24 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
so does that mean I need smaller air bleeds EDDIE B
Maybe. As stated, make sure your idle mixture screws are evenly set first. Air bleeds control air. Larger bleeds give a leaner mixture, smaller bleeds give a richer mixture. Idle air bleeds, the outside ones, will affect the idle mixture up to, generally around 3000 rpm. The smaller high speed bleeds will affect the higher rpm fuel air mixture. The cam and carb size determine the rpms at which the bleeds affect. This is all "generally speaking". From what you have discribed, the carb is running too lean for some reason.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
