68 road runner dash #713250
06/01/10 01:56 PM
06/01/10 01:56 PM
Clintwood VA
johnedod Offline OP
johnedod  Offline OP
Clintwood VA
Voltage limiter stuck and killed my gauges Saturday. Considering sending a core cluster to a rebuilder for an exchange and they were inquiring about which temp gauge I'd need. On some the normal range is about 2/3 to the right and others are about center. After searching several pages on here I found a post suggesting the ones with the normal range centered were later production. Is this correct? Also most I've seen have a white cross on the tach/clock delete plate. Mine is all black. What would be correct for a car with a 7/68 build date? If I do have to spend the big $$$ I may as well try to get the correct stuff. (Not sure my cluster is original to my car).
Thanks!
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 68 road runner dash [Re: johnedod] #713251
06/01/10 03:32 PM
06/01/10 03:32 PM
Virginia
rm23j8g Offline
rm23j8g  Offline
Virginia
My RR was built in late June of '68. It had an oil pressure gauge installed where the tach goes when I bought it in 1976, so I can't tell you for sure about the correct blank plate. I bought a used blank plate years ago and removed the gauge.
I know the cluster is original otherwise, so if a pic of the temp gauge would be helpful, I'll shoot one this evening and post it.
Re: 68 road runner dash [Re: johnedod] #713252
06/01/10 05:53 PM
06/01/10 05:53 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Well the blacked out filler ran untill at least early Feb. 1968 at the St Louis plant. The gauge I'm not sure on but I have four clusters here from cars with spd's late 67 to June 68 all have the 2/3 style range. You car is pretty early so I would say the other style is correct.
If you are interested in a nice used cluster PM me.
Re: 68 road runner dash [Re: rm23j8g] #713253
06/01/10 06:44 PM
06/01/10 06:44 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Jim,
Your car should have the cross.
