67 Coronet R/T with A/C, alum. pump housing ?
#713118
06/01/10 11:31 AM
06/01/10 11:31 AM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I'm having trouble with the aluminum water pump housing on my big block.
stock 440 in '67 R/T, with factory a/c. Started putting it all back together with the new Mopar aluminum housing, and the A/C now doesn't fit right. The alum. housing is about 1" taller than the stock cast iron piece, so now the compressor hits the radiator hose just above the filler neck at the top of the pump housing.
So...do I go back to the original pump housing, or could I get an angled t-stat housing and make it work? Anyone else have this issue with this part (aluminum water pump housing?)
Thanks!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 67 Coronet R/T with A/C, alum. pump housing ?
[Re: AdventurerSport]
#713119
06/01/10 12:05 PM
06/01/10 12:05 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I did the same thing on the wife's old 67 Fury 440 car w/ factory AC, very same issues, gave up and ran the cast iron housing. Sorry I don't have a solution for you.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: dOrk !]
#713121
06/01/10 06:23 PM
06/01/10 06:23 PM
AdventurerSport
Morningside
thought it would look nice, as a dress up item, that's all. No big whoop, we'll switch back to the cast iron housing tomorrow and it'll be all stock. Thanks!
JS
#713122
06/01/10 08:00 PM
06/01/10 08:00 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
Your car would originally have had a special A/C only stat housing that exited straight toward the passenger side. That`s what`s missing.
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
