70 B-body camber adjustment and steering #71306
06/10/08 11:34 PM
06/10/08 11:34 PM
Anonymous OP
Anonymous OP
the camber of my front 2 wheels (the top of the wheels is pointed in and the bottom is pointed out). The camber is exagerrated, whats the procedure for setting the camber?
my second question is in relation to the picture below.
Re: 70 B-body camber adjustment and steering #71307
06/10/08 11:35 PM
06/10/08 11:35 PM
Anonymous OP
Anonymous OP
what should I do about this condition with the steering.... why is the coupling loose and what holds it to the spline on the bottom?
Re: 70 B-body camber adjustment and steering #71308
06/10/08 11:45 PM
06/10/08 11:45 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
If that's the condition of the coupler, I'd investigate the front end parts closely before I'd worry about an alignment, it won't hold it if they are shot.
The coupler shoes are held by a pin inside, I'd pull it apart and check it for wear and any critters stuck in the grease then put a new seal and get the spring clip to hold the cap back on the coupler. I'll check or maybe some one will chime in with a link for it. much easier then trying to bend the tabs back to hold the seal. The guy who sells the clips is a member here.
Found it... http://www.mopar4sale.com/index.htm
Edit the coupler housing is held on the spline by a roll pin in the hole that you can see in the pic, it only comes out and goes in one way tap it out with a punch : if it won't move turn the coupler 180* and try again.
Re: 70 B-body camber adjustment and steering [Re: R70RUNNER] #71309
06/15/08 03:32 PM
06/15/08 03:32 PM
Anonymous OP
Anonymous OP
that website seems to no longer function?? his email address is sending back failure notices.
i found one on ebay, but they only have the short version. I need the long (3 1/16").
Any ideas where to find it?
Re: 70 B-body camber adjustment and steering #71310
06/15/08 05:19 PM
06/15/08 05:19 PM
Anonymous OP
Anonymous OP
I just got an email back from the guy on ebay and he says that his supplier no longer makes them.
Anybody have any kind of leads where I can go to find this part?
Re: 70 B-body camber adjustment and steering #71311
06/15/08 06:20 PM
06/15/08 06:20 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I have just tried the link above and it works. Try it again to see if it works for you.
Re: 70 B-body camber adjustment and steering [Re: Blakcharger440] #71312
06/15/08 08:29 PM
06/15/08 08:29 PM
Anonymous OP
Anonymous OP
sorry i wasn't too clear, the website works, but the email address is no longer valid. the company must be out of business.
